Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
Lidmotor
All----I hooked up my crystal circuit to a scope today to verify that I was at the right frequency and wave form.  I am.  When I get my function generator in the mail it should produce similar results ---I guess.  Hooking that up to the tail end of mt setup should light up some leds. We will see.
  Dr. Stiffler made a comment on my last video and stated that the exact frequency is 13.6 but that I was close enough at 13.56MHz.  My cheap computer O- scope showed a good sine wave signal from 13.4 to 13.7 MHz.  The spectrum analyzer function showed a tall spike at 13.5 which looked very familiar and was what I was hoping for.
   Here is what my scope showed me today:
https://www.youtube.com/watch?v=J95knDhEHZI
Cheers,  Lidmotor
NickZ
   Lidmotor, Slider, and All.
   Great to see some advancements toward the Docs project on our forum.   Also good to hear the the Doc was able to relay the message about the 13.6MHz (magic frequency).
   I think that you've also verified to some degree, that the exact tuning of both your crystal oscillator frequency (13MHz), as well
as the L3 coil have to be in sink. At the same or a harmonic frequency of the 13.6MHz, or there's no cigar.
And also that when the circuit is in tune, no ferrite is needed. Nor clip leads to increase gain.
And, any where the circuit is touched with a finger, only dims the output, by possibly changing the running frequencies.
   Anyways, good work Lidmotor, and Slider.
   It's seams best to replicate the Docs circuit ideas,  as closely as possible.
   Hopefully I'll be able to get my act in gear, soon.
   My main concern is to see what gives with this circuit and its various interactions. And, to see if there's OU, or not.
And to see if a higher input yields a higher output. I imagine the size of these small coils are one limiting factor, but, who knows.   Also, to see if and how this circuit can be looped, to self run. Which is my main aim. As I think that it can be possible to do.
   BTW: Lidmotor, would you be so kind as to unwind that SEC L3 coil, and tell us the exact amount of turns, and wire size etz....   Just kidding...    But, I have been looking for that info, for a while now.  So, if there's anyone out there that knows about the L3 coil specs, please let us know.
                             NickZ
erfandl
before the crystal circuit parts received, I testing the extracted LED from the filamnet light. driving the LED with a super joule thief circuit and a 2.7 volt 500 farad supercap. the LED is running for 30 min
Tomorrow testing with crystal circuit and share the result.  :)
AlienGrey
i'm using a 13.5 mhz crystal (approx) and a smd 1.mh choke, the home made L3 is about 22uh but if i shuve a ferrite bar down it's center
it peeks at 49.1 uh. see pic.
I dont have a HF SG but I do have a 74hc4046 on a bread board it will do 35mhz easy, i have optimized it for 3 to 20 Mhz
I get another peek at just over 6mhz no spike, I use the scope as freq count'r.  8)
Lidmotoor In his video i cant see where he is getting the spike from on his waveform  my Rigol doesn't show it.
PS current draw is 17ma at 10.3 volts, what's all the fun about in this circuit ? free energy, only for the power greed minions !
mikrovolt
I designed a small Colpitts 6.7 Mhz it draws 2 mA.
The intended to be used with 6.7 Mhz crystal then a doubler 2nd stage.
