Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
AlienGrey
Ramset please explain why you believe the energy is coming from the grid, do you mean his hearth loop and SG power transfer ?
Sujeset you talk to Dr Stiffler and ask him to explaine
How to wind L3  (file:///C:/Users/Tarotbug/Downloads/17695261-Wireless-or-OneWire-Energy-Transmission-Construction-Guide%20(1).pdf)
AG
DrJones
   Slider (Mark) is doing some very intriguing replication work, using a small signal generator NOT tied to the grid...
SFM slider may 27 part 1:  https://www.youtube.com/watch?v=NYk1mAAzGb8  up to 9Mhz sig gen
SFM part 2 may 27: https://www.youtube.com/watch?v=J3zQCg16r7A&t=5s
Keep up the good work, Mark!
ramset
AG
I think you confused my "no comment" response [just Stiffler quotes from the video] with Stefan's questions above ??
Ramset quote
Dr.Stiffler says he carried the secret long enuff??He calls it
"The Diode Loop"
or Stiffler Loop
https://www.youtube.com/watch?v=XhdfwmeWevs&feature=youtu.be
end quote
Slyders  replication again
Thanks Grandma
DrJones
  Here is lidmotor's replication-simulation of the SFM:
https://www.youtube.com/watch?v=iNMsynVKngo
  Below is his schema of the SFM.  What I don't understand is - how is the signal generator (one wire only) "hooked up" to the toroidal coil?  can anyone explain that?
Slider2732
Well some great news from here - i've got it running !
Set out yesterday to have the connections as per the SFM original, no direct electrical connections to anything.
Battery operated signal generator, with signal wire to the magnets on the right side, piece of plastic, the magnets are stuck to the coil.
There is no direct connection electrically anywhere.
The thing is though that the signal generator isn't putting out 20V+ and there is a lot of room to improve the L3. The 1W LED is dim and my magnets are of tiny force compared to Dr. Stiffler's.
The big 'trick' is the use of a ferrite rod in the L3, for my replication at least.
Am editing the video bits together and then will post the vid  ;D
It's a step by step in a way, of looking to get it running by the video end.
Will also do a vid of it running outside if there is need to do so.
