Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
NickZ
  TinMan's neon is lit, but it can light with 70v or sometimes even less voltage, and not the 200+ he is stating. As it is just barely lighting the neon...
You can try a regular voltmeter, to see what it reads, also. Sometimes they can read the correct values, on something like this, but mostly they won't read correctly. Just like the Dr. showed, (incorrect scope values).
   Please place any circuit or coil away from the table, on some styrofoam (or similar), and elevated off of the table by a few inches. Same thing with your SG, and it's wires. Turn off you house breakers.
   Otherwise you're just fishing for stray AC.  I'm sure you'll find that stray capacitance, all over the house.And you'll be fooled by it, lighting an led bulb.
AlienGrey
Quote from: Slider2732 on May 31, 2018, 01:05:38 PM
Oh you are quite right...I tend to build with what I have. If it seems to work then things get more exacting, a route for disaster but works sometimes lol
Anything built away from what's shown can only be pseudo and i've hardly ever referred to something as a replication, unless it's open ended as to what can be used.
The method being the important thing.
It does look like that plethora of fakey fakes doesn't it. I'm thinking that something, somewhere did work as was described and the fake vids are merely copying the look of it blindly for Youtube hits and ad revenue.
TinMan just showed a vid where he used 2x axial inductors as an alternative to an AV plug for the SEC type experiments.
https://www.youtube.com/watch?v=lyX9nRrym3Y
I decided to have a go at that with bits on the bench.
The inductors are regular wound types, 2 different values. It didn't work with the sig gen, but does work with a SWES (Simple Wireless Electricity System).
15 turns bifilar pancake, S9014, diode from battery negative to Emitter, 1.5V AAA
It's kind of neat how no trailing wire or clip lead is needed and it stands up on the coil.
It's difficult for me to understand the American jargon  ;D no offense there.
The photo shows what looks like a ribbon cable ? if so are the layers interconected ?
any chance you can show more detail ? and whats Wireless Electricity System about ?
AG
NickZ
   Dr. Stiffler just posted another new video. By adding another diode, he was able to obtain a higher output at the cree bulb.
NickZ
   Here's an old video of mine, showing what the stray AC can do to light an led.
   This is why I recommend isolating the device from this type of influence.
Otherwise you will be fooled by thinking that you are havesting Aether, from the ambient, when in fact it's just stray capacitance of the AC from the house wiring.
  https://youtu.be/Xur_VChGdzE
  And here is the Doc's latest video:   https://youtu.be/2Z9ae0MkfbQ
Slider2732
AG - your comment was pure gold there about the Americanisms. I'm English, but live in the USA  ;D
I do though acknowledge the strange cross-over in language use that has developed.
The coil is a flat single layer pancake, 2 wire core wound around and around on itself 15 times and secured with superglue. 9 turns is about the minimum, extra turns than 15 don't yield extra output. The circuit will saturate above about 3V, so a 1.5V AA or AAA is ideal. Old 56K modem cables are ideal. A diode from either battery connection can reduce current or heat, as can a resistor to the Base of the transistor, but then it starts to step away from being the simplest wireless circuit possible. It was named 'Simple Wireless Electricity System' or SWES.
I know it's not the focus of these experiments and I don't sell them or anything, it's always been Open Source since 2012 and replicated without acknowledgement ever since (not that it's needed).
Vid link to explain: https://www.youtube.com/watch?v=dSUGXCWIVoI
An even easier and simpler version is SWES 2, 2 coils of wire wound around a medicine bottle as a former.
https://www.youtube.com/watch?v=VpGRghguv2g
There is a point to trying the Dr. Stiffler experiments with other forms of input, especially Exciters, because folks are having troubles building or acquiring 20MHz signal generators !
These simple things of mine are an extra route of doing so.
Yes indeed Nick, outdoors demo's are becoming ever more needed. Also, motors and filament bulbs for better power showing than LED's. A gent on Youtube suggested that and I quite agree, mains being a heck of a deceiver to the results of experiments.
