Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
AlienGrey
yes the one frequency that keeps cropping up is around 8hz ie no remainder when divided down 12/8 is a whole number
I assume its to do with the earth's resonant frequency if that's true or not, who knows.
NickZ
   Hoppy, and AG:   Here is an older video posted by Dr. Stiffler.  It is showing what "special frequency" he is tuning his PSEC to.
This is why he tunes the L3 coils, as well as the oscillator frequency to that particular frequency.
He is not sure just what causes that frequency pulse, but has tuned all his coils and oscillators to it, as it causes the highest peak.
   He now uses the 13.5MHz frequency, for that same reason, as far as I can tell.   https://youtu.be/MtphlQ85yg4
NickZ
   Guys:
   My latest video on YT;   https://youtu.be/BZsvtlA_Rgc
    The above video is about  another diode loop test, but this time with separate diode loops, and separate bulb connections.   Seams that the strongest, brightest lumen level is obtained from a single gutted 120v 8.5w led AC bulb, instead of using two bulbs. But, that might just the type of bulbs that I'm using, instead of using the recommended CREE led bulbs. But, they were a lot more expensive and harder to find exactly the ones that the Doc is using. Maybe it's not that important, but they may work better.    As my bulbs are only showing about 1/2 or less of the normal 800 lumen at 120v, I'm still trying to improve on their performance.
doktorsvet
Hi NikZ!
Is there a Dr. Stifler scheme in the public domain?
NickZ
   There are videos on youtube under Dr. Stiffler.
   This thread is dealing with his work and ideas.
   You'll have to look at the Doc's videos if you want to find a diagram or schematic.   You can also try to build up something like this device, below. Or a crystal oscillator, such as the one I'm using.
