erfandl
Quote from: Slider2732 on June 15, 2018, 10:29:17 PM
Skywatcher123 - first of all let me apologise for getting your name wrong in the video below...am new here  ???
I had a look at your multi-turn Primary idea and must say that it's a great idea !
36 turns of the same 30AWG as the main coil. But the main coil is split in half as another difference.
The DMM seems to have messed up though, it reports 19.5mA at 5V  8)
Half decent light out of the 8W DT bulb, the 12 diode ring similar to Dr. Stiffler's build runs really really well. The pseudo SFM works wirelessly and the wireless field is all over the table and to a good height above it.
https://www.youtube.com/watch?v=R6uVwFaCDeg
Hi slider. is it modified version of tesla coil ?
thanks
Lidmotor
  Skywatcher----I tried a 40w equivalent led filament bulb today and had good success.  Thanks on the tip about how to take it apart by heating up the base.  I just used a hair dryer on high and used gloves to protect my hands from the heat and possible breakage.  The little circuit board was glued in the base. It worked on the Slayer Exciter I am using and would also work in parallel with a second 40w just like what you discovered.  Fun stuff.
Guyla-----Thanks for the info on the crystal oscillators.  I'm thinking that I will just use 5v USB power now to drive them.  The one that I have been working with the most is the 16MHZ.  For some reason it will stay running all the way down to about 2v and gives the best 'Exciter' effects.  My experiments with a voltage booster amp are continuing.  Mixed results so far.
Slider---- Nice experiment with the Slayer Exciter coils arrangement.  I remember Gary was initially doing something like that on the very first ones.  We were tuning them by moving the primary up and down the secondary. Later on he ended up with the pancake coil primary and stuck with that I think.
      I am going to try the Doc's 'Big Ring' AV plug when I get a chance.  Yours seems to work pretty good.
Cheers All,
                  Lidmotor
erfandl
I testing with tesla coil and 12 watt LED light with 1n4148 diode connected in series
DrJones
  Wow!  it's great to see all the "old guys" jumping in on this one...
  I've been following quite a bit - via youtube mostly.
  Mark writes:  "The DMM seems to have messed up though, it reports 19.5mA at 5V  [/font]"
That is amazing, probably quite accurate.  Would you pls see what happens when you remove some of the "satellite LEDs"?  I wonder if the power will drop much (or not).
  Also, Mark - could you pls measure the input power when you use a crystal oscillator as the driver?  wondering if it will be more or less than 100mW...?
Thanks for doing measurements!  Now if we could just also measure Pout... !!
PS - I've been doing some experiments on my bench too, but rather quickly burned out my little signal generator (sigh...).   I was lighting up an LED bulb quite nicely, when it blew...
Lidmotor
Dr. Jones----I agree with you that it is great seeing some of the 'old guys' resurface for this project.  Whether they agree or disagree with what is really happening it is good to hear from them again.  Sorry to hear about your signal generator failure.
erfanell ---- Glad to see you using one of those 'Musical Mini Tesla Coil' Slayer Exciters for this project.  I just did an experiment with mine this morning driving a 'filament led' like what Skywatcher123 did.  Those little under $10 'Mini Tesals' devices work really good for this project. This where I got my mini tesla coil kit for $5.49 shipping included:
https://www.newfrog.com/product/mini-music-tesla-coil-plasma-speaker-electronic-field-15w-diy-project-kit-203125
All---This is what I did with it this morning:
https://www.youtube.com/watch?v=ojRZdeAEcdw
