mikrovolt
A schematic drawing of the Stiffler loop. Please let me know if there is an error so I can correct it.
This is the revised schematic. Should be correct now. what was the Doc's SG frequency and voltage ?
Lidmotor
Mikrovolt---  All the 1n4148 and LEDs  are connected (+) (-) (+) (-) etc.  You have one LED connected backward. Maybe it was just a typo.  It is just one big ring of series connected diodes.
Erfandl-- I really want to build that.  I just have not had much luck with it so far.  I have all the parts but for some reason mine is not working like yours.  I will keep trying.
---Lidmotor
erfandl
Quote from: Slider2732 on July 30, 2018, 07:00:13 PM
Thanks Mr. Hewitt :)
erfandl - I wonder how these are in sync with each other. Are they in sync, or overlaying at the same frequency ?
I probably missed it, but is the input wattage comparable/better than stock connections  ?
It's a very neat idea !
I don't know too ! the circuit is pulling 307 mA from a 12 volt lead acid battery. the light brightness output is like when the bulb turned on with 220 volt input.
erfandl
Quote from: Lidmotor on July 31, 2018, 01:49:19 AM
---Lidmotor
Lidmotor - hmm I think the shorter L3 wind coil is working because my L3 coil is shorter than yours. I tested this circuit with Axial inductor but the circuit output performance is very poor. I suggest you testing with barrel inductor.
erfandl
loop diode with 16 LED and 100 v 16 uF cap.
