itsu
Nick,
all good points, thats why i stopped working on these circuits, its not really of practical use and i do not see that
it will lead us anywhere for the time being.
Itsu
NickZ
   Itsu:   Aren't the two cap on the loop supposed to be 10nf, instead of 100nf? Would that make any difference?
I already have a 0.1uf cap before the L3. And two 0.01uf caps on each loop.
   Looks like the loop leds are not as bright as your single led placed in the middle.
itsu
Nick,
the reactance of 100nF at 13Mhz is 0.12 Ohm, the reactance of 10nF at 13Mhz is 1.2K, so therefor i went for 100nF.
https://www.allaboutcircuits.com/tools/capacitor-impedance-calculator/
Indeed, the single led is way more bright, but its a sensitive led.
Itsu
gyulasun
The reactance of a 10 nF capacitor at 13 MHz is 1.2 Ohm.  You could measure only a small, negligible difference in performance versus a 100 nF capacitor in such, relatively low power setup when a 10 nF is in series with L3.
When two 10 nF caps are included in the loop, they may have some current limiting effect ,  consider 2 x 1.2 Ohm (at 13 MHz) instead of 2 x 0.12 Ohm.  If loop current is say 10 mA, calculate the voltage drops across them using Ohm's law and learn the difference.
itsu
I did it again,  silly me.
Gyula is right off course,  10 nF capacitor at 13 MHz is 1.2 Ohm.
Thanks, Itsu
