THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
NickZ
   Phone tablets are handy as well. Don't need to pack a docking station.They can connect direct to mouse and keyboard by USB. Mine also has HDMI.
WhatIsIt
Quote from: ramset on June 21, 2020, 01:23:13 PM
Whatisit
  Perhaps if you could make a checklist of information you do not have to do the replication and we could start to gather that information towards a PDF
First my apology to Chris.
At first I was mad and thought he must wanna publicity,
but then I realized that I could be very wrong.
I used first core I found, and I did everything in hurry.
I think I failed in directions of diodes.
Could be anything.
Will do again with more care when I come back home in a day or two.
Not sure now what I did wrong.
Must be directions of diodes.
Chris used toroid, close loop core, and I probably looked at scheme,
where is not drawed shape of core. So, I made stupid error. Probably.
Thanks!
Could help if Chris draw shape of core on scheme, it will be easier to follow direction.
And there will be no room for mistake.
And, sorry Chris for my words.
Nick, yes, the tablet idea is very good, but I have to use mobile phone,
I driving a lot and is impractical for me to use tablet.
phone always can put in pocket, and lots of other small reasons,
like typing message with one hand, and on, and on...
but thanks for the tip.
For me, problem arise when come to hotel and must unpack laptop,
then transfer needed data or files from phone to laptop just to do some work,
lets say in MS Excel and when I am done transfer data back to phone,
because all work I am doing while driving with my phone during the day.
Laptop serves me only to prepare files or data or tons of documents needed for work.
But actually phone is my bussines hub.
Nightmare!
AlienGrey
On your I phone have you found the thick film antenna around the battery covering?
itsunder the fancy label.
Apparently its for remote eves dropping and down loading what's on your phone.
I bet it records and sends off data where ever you are or what you're doing.
a clever surveillance device and tracker.
EMJunkie
Quote from: ramset on June 20, 2020, 09:10:51 PM
perhaps he does not realize you are a builder too [when intrigued ]
we have had persons here in the past who engaged or critiqued but would never build.[sometimes very good reason]
here I am certain if all info gets put into simple replication document
many more persons would build..after all it is remarkable claim.
I am trying to get info into a small PDF ...most don't need to be sold on such a simple aboveunity claim...just need a simple presentation [schematic , spec sheet all relevant info and expectations [expectations already noted "aboveunity"
There are no "remarkable" claims if one knows what they are doing!
Partzman, Here, has three little coils, and measures Above Unity, in point of fact his last claim was: 1.48
There is nothing special, if one understands what they are looking at and the direction they must head in! Energy is Pumped from Source! Source is the Copper Atom! Magnetic Fields are the only field that can influence the Source, as the Charge, and therefore the Magnetic Moment, are susceptible to an External Influence.
So many before us have not found the result they were looking for, simply because they did not understand the Requirements! In depth study of the Electrical Generator, has been the catalyst for the success we have seen in History, even Clemente Figuera said it:
Quote from: Clemente Figuera
Watching closely what happens in a Dynamo in motion...
To many people have been off chasing rainbows! The BS of Cold Electricity, Radiant Energy, and all the other magical BS that so many have in their heads that was planted by the dissinformationalists! Its all LIES! Accept it and move toward Logic, Fact and then you will make progress!
Every success story I have researched, either studied in depth the Electrical Generator, or knew its internal workings very well! Not a single success story has any Magical BS in it!
So, if partzman can make three little coils work, then so can you! I have been showing this for nearly a Decade, many hundreds of success storied have been reported t me. Most are un-willing to share because of your approaches and attitudes here! The Trolls!
Try harder, think harder, focus on Facts! Use Logic! Wipe completely from your minds Fairy Tale Science!
See Partzman's replication of Partnered Output Coils below:
Best wishes, stay safe and well in these dire times,
   Chris
ramset
Chris As stated before no one has ever found an OU claim at Overunity research that would survive the separation from the bench power supply ,batteries  ,or closer scrutiny.
always the error has been found .
many times partzman has thought he was onto a gain mechanism [above example] which was truly an anomaly [yes did seem to show OU],yet none has survived the ultimate test....An ability to selfrun with no input from external sources.
and still he tries...
your claim from my perspective is truly unique,and yes I absolutely believe there could be many who feel they show aboveunity on the bench.
However a stand alone device should manifest if gain is high enuff [no batteries ..or connected to equipment or??]and even 1.1 should be able to daisy chain I am told ?I am unaware of a 1.1 claim which survived closer scrutiny .
your claim is unique IMO and wonderful you share it .cop 1.9 should be off to the races...[still trying to get your info into a simple document for builders]
thank you,,/
    Chet
Thanks Grandma
