THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
stivep
Quote from: TommeyReed on August 05, 2023, 09:29:26 AM
rakarskiy,
My question is, whats in it for you? Are you one of those investors that might loss money due to the fact the system is not what it claims to be or a salesman?
I do not agree with rakarskiy in  few areas but
-the only what matters to me is that he is this particular Ukrainian.
As if you would say Tommey  The only what matters to me is that this boy is my son.
But  rakarskiy - is really good in our field Ukrainian from Ukraine (-They buy guns now. ), so he can not be  Holcomb salesman.
Now you can compare him to your son if you have one.
Wesley
AlienGrey
Quote from: stivep on August 05, 2023, 08:27:57 AM
Very true: it is Energy for Free = Free Energy= FE
Your Father  gives you FE = food for free and money too .
For solar, wind, water in the river, - one time cost of energy converter makes it  FE.
Energy of magnet  can't  be used as FE as there is no energy there.
To be more accurate
the old school says:\Free_energy_from_permanent_magnets#:\
the new school says:
Extraction of energy from magnetic field of a magnet is impossible because magnets do not contain energy.
https://engineering.mit.edu/engage/ask-an-engineer/why-cant-magnetism-be-used-as-a-source-of-energy/
Wesley
A magnet does not contain FE, That depends on your donation of  FE, but it's a self runner
it powers it's own existence and goes on and on you cant easily destroy it unless you can smash it
and make it into smaller sections, lets take electricity it's two parts one part is magnetic and it goes back to
the generator the other  part is dead on arrival. Other wise you would only need one wire.
Still got a problem with it ? then get an old TV circular madgnet wind a coil round one of the arms
and atatch high impedance headphones to it, what's that noise you hear ?
Sil
AlienGrey
Quote from: onepower on August 04, 2023, 08:34:30 PM
I agree conceptually but it begs the question... extraordinary or unbelievable to whom?.
Having done decades of research on FE and seen many working devices first hand I don't find this technology extraordinary in any sense of the word. I think it's problematic because logically the least educated who understand almost nothing find everything extraordinary, do they count?. I mean, if a flat Earther who rejects all conventional proof thinks your nuts because you think the Earth is round are both your opinions equal?. So if you objected to the flat Earther's opinion why couldn't I object to yours using the same reasoning?.
What defines extraordinary?, well it explains itself, extra(beyond, above) ordinary(common, average). Any concept beyond an ordinary persons understanding with an average high school education who doesn't understand 99% of science. Ergo, the lowest common denominator, ie. something of small intellectual content designed to appeal to people who understand very little.
It took a while but I think I found the reason I succeeded where you obviously didn't. I think like a programmer and everything relates to logic, reason and factual information. The better and more accurate the information the better the odds of success. Thus, I always look to the highest common denominator not the lowest average and popular opinion... this is not a popularity contest.
AC
life time of research? so what did you achive did you get any thing to work ? :o :(
stivep
Quote from: AlienGrey on August 05, 2023, 10:12:58 AM
Still got a problem with it ? then get an old TV circular magnet wind a coil round one of the arms
and attach high impedance headphones to it, what's that noise you hear ?
Sil
1.Connect your scope (spectrum analyzer)to  headphones and measure frequency than connect  this coil on the magnet  as an antenna into a scope and search for source of that noise.
2. place your magnet with the wire on it inside of faraday cage - you'll hear nothing.
some explanation:
if coil is wounded on the magnet  than you may hear some magnetic domains changing its polarity.
But you may  just place on that magnet  medical  doctor stethoscope and you'll hear the same, the crackling sound of mechanically switching domains.
To magnify this effect  drop magnet on the hard floor  or knock it  with some  hammer ( it can be rubber too) and immediately listen using medical  doctor stethoscope  for the sound of mechanically switching domains
https://youtu.be/4GLdCEQii5A?t=260
Wesley
rakarskiy
TommeyReed, the way Holcomb's system works, I already said as a traditional synchronous oscillator. But with certain problems of its own.
First if you put a Holcomb solid state rotor into a traditional generator stator, the phase output will not be a pure sine wave, but a peak spike pattern.  The solid state rotor is inferior to the traditional electromagnetic rotor, in forming an index of initial magnetic induction on the pluses in the same size rotors. The sine in a traditional oscillator is formed by the shape and variable clearance of the pole tip, which is impossible to accomplish in the solid state version.  You don't need to be a professor for this, just an understanding of magnetic circuit design. I'm not interested in the solutions they applied to sine wave shaping. Anyway, with the cover removed, I saw a three-phase transformer in their self-propelled version.
Secondly, any device has specifications for operation. In order to fulfill the condition of power amplification in Holcomb converter, it is necessary to observe the proportion of connected load in constant mode: for the value of input power consumption of Holcomb converter 1P=IU, the load in the measure of 1.5-2P=IU is permanently switched on. In this mode you will get that saving which will be expressed in the value of minimum 1.5P - 1.0P = 0.5P.  If you do not provide a constant load in a dimension greater than the inverter consumption you will be at a loss, for example your load is 0.7 P=IU. If you connect the load through the Holcomb converter, you will have a loss in the dimension of 0.3P=IU.  But this is not the problem of Holcomb converter, but of the smart person who operates this converter. This is the control of energy processes at the object. and they have nothing to do with the technical characteristics of the converter.
Watch this video, you will see that the motor-generator is not on all modes of Overunity: https://youtu.be/mq98r-rdayo?list=PLeeRs1tEQlwFEicrLlYa0yWLFiYv-njUY.
Third, I have already explained to those personally interested that the Holcomb Generator is a pilot project. Investments with quick results are utopia. Also there are very serious risks of opposition in promotion on the markets from already active participants.
I hope I have described everything in detail.
