THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
gyulasun
Quote from: FriskyFritz on June 30, 2020, 04:43:12 PM
Are you brainless? You know nothing! Pick holes in others when you don't know.
You are stupid Dumme Person. Siehe eine gerade linie?Fritz
Why did emerge from your jungle?
What kind of component is involved with your blurry and oversized picture?
If I see it correctly, it may show how the resistance of  say a thermistor changes in the function of the temperature.
   NTC (Negative temperature coefficient) type component.
Please learn some civil behaviour or go back to your jungle.  Which is at aboveunity.com as you did write it here:
https://overunity.com/15395/partnered-output-coils-free-energy/msg543062/#msg543062
ADDITION:  here is the link member FriskyFritz  copied the blurry picture from, it indeed belongs to a thermistor:
  https://www.littelfuse.com/technical-resources/technical-centers/temperature-sensors/thermistor-info/thermistor-terminology/resistance-temperature-curves.aspx
gyulasun
Quote from: lancaIV on June 30, 2020, 04:40:09 PM
Hello Gyula,
https://www.youtube.com/watch?v=pKFo4dOW4UU  Just a single DC Pulse, 10%
Duty Cycle of 3000 Cycles per Second. = 90% "Ohms law"  off
Peak 17 Volt or average 17 Volt, peak 0,7 Ampere or average 0,7 Ampere ?!
Yes,here is an open " numbers kind and quality" question and Mister Sykes probably gives answer,included "duty cycle" effect  !
Sincerely
OCWL
Yes,  Mister Sykes probably ought to explain several details and finally show scientific measurements.
Dass Widerstand und Temperatur zusammenhaengt ergibt sich aus der Erkenntnis der Halb-/Leiter-Forschung und letztendlich :
                                          https://de.wikipedia.org/wiki/Supraleiter
Aber es ist kaum glaubhaft,dass mit solch einem " forschem -schamlosem-  Auftreten" wahre Forschungsschritte erfolgen werden !
Vielleicht sollten Sie,Fritz,ueberschuessige mentale Energien in erfolgreiche Experimente umsetzen !
Viel Erfolg
OCWL
EMJunkie
Quote from: gyulasun on June 30, 2020, 05:06:54 PM
WOW Gyula is DESPERATE! He is DESPERATE to attempt to discredit me and my work, DESPERATE to try and make others appear silly when it is him that is looking silly! DESPERATE to pick wording to pieces of others posts and opinions!
Thing is, he is wrong, again, as he was before! Plain and Simple Wrong! DESPERATELY making himself look like a fool in front of everyone, again!
Quote from: ENERGY EDUCATION For Dummies
The resistance of a conductor can be calculated at a temperature of 20°C using:
With increasing temperature, the resistance of the wire increases as collisions within the wire increase and "slow" the flow of current. The amount of change is determined by the temperature coefficient.
Ref: Conductor resistance - Energy Education
Now, plain and simple, Gyula should know about Thermal Drift, and the Thermal Coefficient and how Temperature can change Resistance, but it is clear, he is a Soiled Brat! His Behavior is disgusting towards others!
He does not even know the most simple Electronics Engineering Fundamentals! This is basic stuff, basic knowledge! Every first year EE gets taught this!
What Changes Resistance? What else might change Resistance?
This guy is one DESPERATE DUDE and is falling harder on his face, in every attempt to discredit me! DESPERATELY FAILING!
I wonder why he is trying SO HARD to Discredit me? Who is he working for? Only gets his big pay day if he succeeds? Hahahaha that's impossible!
Now I know why Fritz posted such a big image. Hahaha nice Fritz. BTY: Fritz's work puts you Numpty's to shame! He is Eons ahead of you!
All I see is Learning Impaired Bio Slushies!
@Chet - You can use gyula as an example, the reason all of us, don't want to share with people here!!
@All Reading, you want someone to blame for not having access to this Technology? Here is your Man!!! gyula is your man!
Best wishes, stay safe and well in these dire times,
   Chris Sykes
WhatIsIt
Quote from: EMJunkie on June 30, 2020, 11:06:19 PM
WHICH TECHNOLOGY ?
No one replicated it with success.
At least nobody showed and wrote about it here,
not even researchers from your forum did not come here and celebrate showing results about which you are talking.
You do not have any measurements.
On which basis you call this technology?
On your word and word only.?
I don't know Chris, you got too far.
If you wanted publicity and promote your forum because more people, more donations,
you already used this forum for that in last months.
If you are researcher, then start project here from scratch and lead to first successful device.
But you just copy paste same thing over and over???
No further explanations, instructions.
Will it work if ratio of coils is divided down and used higher frequency?
It should! Why don't you talk about stuff like that, about your device, explain things?
So, what technology ???  Story from your copy paste thread. What are you doing?
You should lead experiments here and not fight with every member.
