THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
ramset
Lanca
quote from link
In their experiments, the researchers reduced the LED's input power to just 30 picowatts and measured an output of 69 picowatts of light - an efficiency of 230%. The physical mechanisms worked the same as with any LED: when excited by the applied voltage, electrons and holes have a certain probability of generating photons.
end quote.
Thank you lanca for picowatt anomaly.
Here Aboveunity Elites have 6 watt input [6,000.000.000.000 picowatts] at COP 1.8 ...they have real meat to eat ....[maybe Aboveunity Elites can Share [Open source] how ?? for those less fortunate who can't pay and not as "privileged"??  ...Cop 1.7 claim was made here 5 years ago  by Aboveunity Elite ...and still no one here has shared open source  replication or tutorial for less privileged ?
And now we see that a post from  V8carlo of funds required to have access at aboveunity forum ?[so not going to be open sourced without ??
If experiments are needed to find anomaly or method to pinpoint a gain in some geospecific location [recent comments in PM have indicated an issue replicating anomaly globally ...then this should have been stated from beginning
I/WE NEED HELP !!instead of so much finger pointing and destructive fire starting by Aboveunity Elites  in this forum...
You need experimenters...to hunt ??SAY SO....making stories of 40 years no success...NOBODY IN HUMAN HISTORY HAS SHARED AUTONOMOUS [no battery etc]
STAND ALONE LOOPED DEVICE..... OPEN SOURCE ....not even "1" watt...[anomalous heretofore unknown source .
Thanks Grandma
"I do need more satisfaction ! I will try,I will .... "
Chet,you rolling stone,at first you get "quantum state efficiencies" : > 1 : not enough !  :o 8) ;) .
( Meine Omi,Lehrerin,leider verstorben,wuerde meinen : Stoffel ! ::)  u.m.o. = unidentified meaning object  ;D   Old school  )
"Efficiencies > 1" -cascaded- let reach unlimited "efficiencies numbers " !
What do you know about  aboveunity their set real input energy and output energy ratio,when there is not given V-average/V-max
        and A-average/A-max ?!
                                       https://en.wikipedia.org/wiki/Root_mean_square
                                A capacitive charge pump circuit with parametric generator function : that is all !
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FFerdinand_Braun
On the transmission side, Braun was also able to help the radio technology make huge advances:
Guglielmo Marconi had largely managed his transmitter empirically , so that Braun could improve it by looking at the physical background.
While the oscillating and antenna circuits were originally one, Braun separated these two parts.
Now there was a primary circuit, consisting of a capacitor and a spark gap, and an antenna circuit inductively coupled to it ,
which increased the transmitted energy in this system.
bistander
Quote from: lancaIV on July 07, 2020, 12:14:31 PM
bistander,
from the contexte
" The researchers didn't try to increase this probability, as some previous research has focused on, but instead took advantage of small amounts of excess heat to emit more power than consumed. This heat arises from vibrations in the device's atomic lattice, which occur due to entropy. "
you not include that " This heat arises from vibrations in the device's atomic lattice, which occur due to entropy. "
so the total output related total input release " over unity effectivity" !
It is internal heat generation,not from the ambient/outer environment !
And in the context, 135°C was required. All I did was read the paper last year, but sure seems like a lot of excess thermal energy around the experiment. And I do not recall the experimenters or authors commenting they had ruled out heat from the environment, in fact, my old memory tells me they said just the opposite. Right now a picowatt doesn't motivate me to lookup and reread that article.
bi
ramset
Lanca
a rolling Snowball effect ?[gain mechanism ?]
Well others are looking at ....light?
And what may be available?
Note : Image below shared with permission of presenter [original topic starter]
Thanks Grandma
bistander,picowatts are not much !  Question here : work area in sqmm
1 sqm = 10000 sqcm = 1000000 sqmm
                                                    thermo or phono-photovoltaic panel
            one quadrillion cycles per second x 1,55 billions cnt x 3600 sec. = 1 hour conversion work per sqm
        cnt=     carbon nano tubes
                            by 45% conversion efficiency we get photon energy transformed :
                 600 Watt  AC electricity by theoretical  "1 sun" = 1333 Watt/sqm solar radiation konstante
                                           600W/sqm = 0,06 W/sqcm = 0,0006 W/sqmm
