Oscillator Powering 6 Modified Led bulbs
Started by SkyWatcher123, April 28, 2017, 12:06:21 AM
Naija
Quote from: SkyWatcher123 on June 10, 2017, 11:34:35 PM
Hi casiano, glad to hear you are having good results, do you have any pictures or video to share.
I picked up 4 more of the same model led bulbs today and converted 2 so far, so the setup now has 10 modified led bulbs and will have 12 total, when i modify the other 2.
There is now even more useful light illumination and the wattage reduced to 7.16 watts, from 8.2 watts.
Based on these results so far, i plan to pick up another 4 pack of these led bulbs, so i will then have a total of 16 modified led bulbs.
Actually, it appears to me, that by adding more led bulbs, we can maintain the same practical illumination as the 8 led bulbs, while reducing the input watts.
Because i notice the area where i did not add more led bulbs yet, it is slightly dimmer, but not much at all, though more illumination in the areas where i just added the 2 latest led bulbs.
So, i conclude, that when i add the other 2 led bulbs to the area where it is slightly dimmer now, that will compensate and probably lower the input watts even further.
This seems to be confirming my theory, that we can get more and more practical light output, by using more and more led diode material.
Let me explain this another way.
Say we start with one 8.5 watt modified led bulb, powered to the full 8.5 watts and this bulb outputs around 800 lumens.
The leds from that bulb may be intense, though the practical, full area illuminating capability of just one bulb is weak.
However, if we take 8 of those bulbs, using this oscillator setup and use the same 8.5 watt input, the light intensity may be somewhat lower, though the real world practical illuminating effect is far greater.
And i know some claim this is just because we are spreading around the light, though i say it is because we are using more led diode material, somewhat along the lines of Joseph Newmans teachings.
peace love light
Hi Skywatcher, I don't know why but am not able to upload the picture of my setup via my android device. But I will do so when am able to work from a computer. Meanwhile, I have been able to light up my modified 5w led bulbs using a 12ah 12v battery. It is a little less bright in comparison to an unmodified 5w powered by grid power. I am not yet able to achieve the illuminance that will burn spots in the eye or the heavenly effect as you earlier described, but I will keep on tweaking.
SkyWatcher123
Hi all, so something sparked my curiosity, and was pondering this idea about using more led diode material.
So i decided to hook up my boost converter and dial it in to a similar voltage that my oscillator capacitor was at.
This is not meant as a comparison between my oscillator and the boost converter, as my oscillator is not built as efficient as it could be.
This test was meant to see if the boost converter was worth using and to have a more controlled higher voltage power supply, to test the more led diode material idea.
Well, i hooked up all 10 modified led bulbs to the boost converter and the bulbs are a little brighter and slightly more white in color, this compared with my most recent testing with my setup at 7.2 watts.
This is nice, even nicer is the fact that it is using only 5.2 watts from a 12 volt tractor battery to accomplish this,
or 420 milliamps at 12.36 volts.
Of course for normal use, i will use the 12 volt computer power supply, to power the boost converter.
Seems to be a very useful setup.
Here is a link to the boost converter I'm using.
https://www.banggood.com/DC-DC-600W-10-60V-to-12-80V-Boost-Converter-Step-up-Module-Power-Supply-p-1041640.html?rmmds=buy
peace love light
casiano
casiano
So,the circuit without the load draws 7.8watts,but when i turn on the lights the power consumption is always 7.8watts.
Could someone explain why?
SkyWatcher123
Hi casiano, very nice, thanks for sharing the pictures, just like they say, they are worth a thousand words, hehe.
Yes, your coil/core looks like it would be more efficient than mine.
If you really want to make those led boards effective, spread and space them out somehow and then add some more if you can get them.
Either way, looks good.
peace love light
Edit: the input stays the same, because once the capacitor is powered up, the only thing adding to the output is the spikes and that doesn't affect what you input, because that is after the fact.
