Oscillator Powering 6 Modified Led bulbs
Started by SkyWatcher123, April 28, 2017, 12:06:21 AM
SkyWatcher123
Hi magnetman, yes above is correct.
Then you can limit the current at the voltage you choose.
I will say this though, removing the circuitry from any of these led bulbs, improves efficiency quite a bit.
Plus, even the best inner drive circuits, will only last so long.
peace love light
magnetman12003
Quote from: SkyWatcher123 on June 26, 2017, 03:36:46 PM
peace love light
Will the boost converter be able to light 9 seven watt unmodified 12 volt bulbs? -- Three groups of three bulbs {in parallel} --  Connected in series with each other so that 36 volts powers all through series connections ??  Do you adjust the output voltage before you turn the lamps on or after the bulbs at lit?
There is a voltage drop whenever a load is applied.
SkyWatcher123
Hi magnetman, yes, the 600 watt boost converter i have will most definitely power those 9 bulbs, easily.
Hook up a 12 volt power source to the boost converter, then use a volt meter to check the output voltage, then adjust to 30 volts, then hook up your bulbs and raise voltage to 36 volts.
peace love light
magnetman12003
Quote from: SkyWatcher123 on June 26, 2017, 11:48:42 PM
peace love light
What do you think of this 900 watt boost converter?   Its output is 10 to 120 volts at 15 amps.
That means you can power 110/120 volt unmodified bulbs with it using 12 volts input as well as any set voltage from 14 volts up to 120 volts. (Output being 2 volts greater than input) ITS DIGITAL!
http://www.ebay.com/itm/New-900W-DC-DC-Boost-Converter-8-60V-to-10-120V-15A-Step-Up-Power-Supply-Module-/291861952982?
SkyWatcher123
Hi magnetman, that looks like a useful boost converter.
Not sure it's as efficient as the one i have, though the description on mine says up to 95% efficiency, where this one states 85% efficiency.
So mine is probably around the same efficiency.
What experiments do you plan to try.
peace love light
