Oscillator Powering 6 Modified Led bulbs
Started by SkyWatcher123, April 28, 2017, 12:06:21 AM
SkyWatcher123
Hi all, i've made some changes with my setup.
I removed all the 24awg. wire from that big core and am now using a single ferrite tube core, with only one layer of bifilar, 24awg. magnet wire.
This way, i can go back to using the 12 volt computer power supply.
It works very good and frequency is much higher.
I also added another separate full circuit, with same type of core and coil, using a separate PNP transistor, also off the same power supply and switch.
I did this for a couple of reasons, one was to get even more light output, while staying with 4 modified 120 volt led bulbs per circuit.
Second reason is because i just picked up another 4 meijer led bulbs and they are not quite the same as the previous ones, so the led bulb loads did not balance when in parallel.
So another driver circuit is a good solution i feel.
Also, these circuits are more efficient than all i have tried so far, i'm sure the high frequency is part of the reason.
Not quite finished yet, i have to run a separate line to the ceiling. to the other set of 4 led bulbs.
When i finish, i will post some pics and circuit drawing.
peace love light
magnetman12003
Quote from: SkyWatcher123 on May 07, 2017, 01:44:35 AM
peace love light
Where are you buying the ferrite tubes?  I have miles of 24 gauge  wire and am very interested in your doings. Love to see your circuit and photos.
magnetman12003
SkyWatcher123
Hi magnetman, i had previously bought the ferrite tubes at a place called american science and surplus.
They are just over an inch in length, i just super glued 4 of them together to make the core.
peace love light
AlienGrey
Quote from: SkyWatcher123 on May 07, 2017, 01:11:42 PM
peace love light
it sounds like he is using ferrite rings, try it with some of the high impermeability ones on the market like Farnell ect.
good luck. AG
