Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
MenofFather
I tryed and lower voltage about 8 V and 0,07 A, then on output I get 21 about volts and so on output is 0,441 W and on input 0,5705 W. Frenquency 85 kiloherc. Resistor same 1 kiloomh.
MenofFather
In Alek Divice one secondary have 15 omhs, other 17 omhs. So if output curent is 0.427 A RMS, then if coils conected in sieries on they be voltage U=IxR= 32 omhs x 0.4=12.8 V. Power disipated on this secondaries be 12.8x 0.4=5.12 W. So output is not 4.53 W, but 9.65 W of heat. So Efficiency real is not 609 precents, but about 1300 precents.
justawatt
working split flux transformer
https://www.youtube.com/watch?v=fyLWDJ1Uejo
Entrance - 220 Volt, 0.5 Amp ( 110 Wat) Output - 660 Volts, 1.0 Amps ( Wat 660) Load - 600 Wat.
If the load is different, the consumption and output is also different
Transformers 2 kW, each with three windings, each on 110 Volts.
MenofFather
Quote from: justawatt on May 15, 2017, 02:27:47 PM
From were you get, that input is 0.5 amps? In viddeo is 5.5 amps, and then shorted turn, then about 4.5 amps and 220 volts. On output 600 W  light on 190 V (with shorted turn). So input 990 W. output 500 W.
justawatt
before that the device is loaded with series 600 watts light https://youtu.be/fyLWDJ1Uejo?t=1m17s
yah you are right 4.5amp is the value in the video that is when he add the 2 kw heater in the bottle you see https://youtu.be/fyLWDJ1Uejo?t=1m27s
and 5.5amp when he short the coil that smokes after some times.
when this happens input is around 1210 watts and output 600 watts light + 2kw heater coil
I am in contact with the author of this video ,he explained what he did at each stage.
