Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
seaad
Hi guys
I have only made some tests with a special H-brige, with extremely low idle current, driving a tuned high voltage transformer.
Mainly for testing my type I + II transformers  with a higher voltage input. The COP remained the same.
After that I have been busy with some house and garden projects.
info here;
http://www.energeticforum.com/renewable-energy/10394-bi-toroid-transformer-thane-c-heins-22.html?highlight=toroid+seaad
Regards Arne
nul-points
hi seaad
very interesting results with your multicore!
i have an old multicore i made, inspired by the early Jensen design (which was a long time before Thane Heins BiTT)
as you can see from the photo below it has a common winding on the 2 narrower core loops, but i can remove the winding, separate those loops and rewind a primary on each to emulate your design (the core on the left is another, thicker toroid seen from sideways on)
i see that both you (and Jensen) have used AC drive but i'm more familiar with pulse operation, so i think i'll try that first
good luck with your tests, thanks
np
Hello seaad,  probably you heared about Heinrich Kunel and his "static magnetic generator",
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820128&CC=DE&NR=3024814A1&KC=A1#
he also wrote about "his device multi-fold cascading" up to MW-output range. Electrical  transformer coupling   how easy/ difficult in financial costs , especially if to include electrity output kind , DC or AC or pulsed AC, ? ----------------You ,seaad,are real experimenter, not only theorist :----------------
So my thinking and this related my question:---------------- transformer overload protection https://en.m.wikipedia.org/wiki/Inrush_current
each electrical device has for some pulse cycles inrush current and /or inrush voltage ,up to 100 times the nominal value,  so how are you/will you treating this short but to overcome barrier,which kind of " bridge/ glider" ? Inrush limiter ? For each cascade/couple  step a battery/ capacitor bank?
https://www.ametherm.com/inrush-current/inverter-inrush-current-protection
seaad
Quote from: lancaIV on December 18, 2018, 09:37:19 AM
So my thinking and this related my question:-- transformer overload protection https://en.m.wikipedia.org/wiki/Inrush_current
H. Kunel: Yes i have tried that with some gawky experiments. No luck so far.
But I also made many experiments with the split-trafo types without good results first, until suddenly! > 100%. (above my probes, scope uncertainty)
Much of the effect comes from the right core material type (I don't say mine are optimum here)
   See: http://www.energeticforum.com/307037-post642.html
And the core size ratio.
Inrush voltage is not an issue right now. The important thing now is to bring down the need of Kilo-Volt to the primaries.
Regards Arne
I thank you for the answer, but the question was not specific the Kunel-device related( this only stated as example how to treat with great numbers and couplings with several " inrush phase" connections) )  it was and is a geral question:what is the physical and financial cheapest and easiest way to treat this "inrush phase" between couplings in electrical devices ?!f.e.: from a battery to - 1.connection and inrush step - an inverter to - 2. connection inrush step - a motor ......by consumer "no-load up to full load" conditioning!variable " soft drive" arrangement ?-------------------------------------------------------------
https://contest.techbriefs.com/2017/entries/sustainable-technologies/7503-------
frequency ( ~ pressure) and output variation : chaos-butterfly in a shoebox
Do you know about the " windhex/Wind witch" internal  process ? -
https://en.m.wikipedia.org/wiki/Windhexe
Variac?  Air core? Carbon Nano Tube ? Thermionic channel ?let us digitize to solid Voltage,  Amperage and Hertzian swinging/ cycling:one is the winding, the other is the wide( band- width/gap) and the last the fluidum velocity pressure
