A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
ageofmagnetizm
Hi Gyula,
I have to point on the fact that all those methodes are exellent for knowing everything about
loads or lamps powered by generator but not generator itself...but knowing power of loads allows to assume that 10 watts lamp shines
because that generator gives 10 or more watts and doubtfully that shining 30 watts lamp means that that generator
is not weaker than 30 watts and so on even without multimetes connecting to circuits.
What would you say on that?
gyulasun
Well, I would say that if you do the parallel measurement instead of the series, then you (we) would also know the generator power it actually produces while feeding the load.
ageofmagnetizm
Gyulasun, the key word you've just produced : "also".
I've collected bunch of various loads from 5 to 100 watts (LEDs, incandecents, thermoelectric)
and 've meassured AC voltages and resistances using both discussed here methods
and ' have calculated powers of all resistors and 've found that independetly from methods
- powers of resistors are same and matching powers given by manufacturers.
I see nothing amazing in it because that physical properties of objects are independable from
methods of meassuments - hence both methods are equally gooood,
same is fo calculation methods where AC voltage and resistance are sufficient for calculation of power
which is the same when its calculated from known current and resistance and/or current and voltage.
Amazing is how rational people change when they face something what simingly contradict to theirs beliefs,
or perhaps people change because that posting commercial links they earn several coints so to say...
Belfior
Yes it is amazing how rational people can use AC multimeters to measure currents and voltages that are not 50 or 60 Hz and still think they are getting accurate measurements.
That is why I suggested going through a full bridge rectifier to a load and then do the measurements with a multimeter. DC is DC no matter what multimeter you have and there is no frequency to deviate the measurements.
You can go on for 6 months with this series&paraller dance that you have OR go through a full bridge rectifier and put an end to this
ageofmagnetizm
Belfior,
Rectifiers where discussed on the second page her and there two links to wikipedia explaining
rectifiers and rectifiers in DMMs, also count that DMM is build for meassuments of AC currents
Within 40 to 400 herts with allowed +/- 1% of presission.
And and here we've made one more page dedicated to obsessions round multimeters while no discussions
of generators.
https://sites.google.com/site/ageofmagnetizm/home/magnetomechanics/hyperefficient-generator
HYPEREFFICIENT AF PMG-MMEIR 4E8M.
Construction and methods of utilization and results of testing of
the Axial Flux Permanent Magnets Generator of Magneto Mechanical Electro Inducting Rings .
Generator is made as experimental prototype and during various testing has
manifested hyperefficiency - converting energy so that output of electric energy is more than 1000%
of the input of mechanical energy
