A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
citfta
Hi ageofmagnetizm,
NO ONE is going to take you seriously until you start to make proper measurements.  That is simply the way the world works.  Accusing Gyula of malicious posting will also guarantee that no one will take you seriously.  He has spent a considerable amount of time and effort trying to explain to you why your measurements are not telling you the truth about what you are doing.  Yet you still refuse to listen.  You claimed in an earlier post you wanted to learn, but that is obviously not the case.  I wish you luck but I don't know how to get you to understand you just don't know what you are doing.  That fact is perfectly clear to anyone that has worked in electronics for any length of time.
Respectfully,
Carroll
gyulasun
Thanks Carroll.
Hopefully he will show correct measurements,  and we may see how his generator performs.
Gyula
Belfior
Quote from: citfta on May 16, 2018, 10:14:31 AM
Hi ageofmagnetizm,
Respectfully,
Carroll
The problem with OU researchers is that they will take any evidence that points to OU and the just boast they have it. What you should do is try to prove yourself wrong and when you can't find any contradictions anymore, then go to other people so they replicate your device. I myself got very exited about my Kunel replication, but then noticed the OU output is 60Hz. That is very peculiar thing to get from an output coil if the primary is getting 2.7kHz input...
Turns out my bench has 60V AC on it constantly. Chinese signal generator that is turned off had the wires on the bench. BNC connector's outer shell and actual ground has 60V AC between them, so the Chinese machine uses neutral as the ground. Pretty nasty thing to find out, but what can you expect since the power cable for the SG has no ground pin on it.
ageofmagnetizm
Belfior,
Past 10 years I moderate here two discussions and reading many others,
Yet I' posted less than 10 comments on discussions moderated by others,
either because I do not take them seriously and spare my time, or my oppinion
wouldnot provide any support or constructive development.
Weird to see people spending ours dayly, made thousands of comments while
having not own business to care about or their business is not being taken seriously
and they spend life in malicious vanities.
Belfior
Quote from: ageofmagnetizm on May 18, 2018, 06:13:09 AM
Belfior,
This is a forum. Forums are for discussion. Revelation comes from discussion.
This forum is also filled with crazy people, people who try to stop free energy, inventors trying to find something new and everything in between. This is the user demography on a public forum.
Few lunatics even post their stuff on multiple forums, so they could offend more people.
If I have offended you I am sorry. I can stop posting all together and concentrate on my business
