Where the OVERUNITY using INDUCTION COILS comes from (eg Joule Thief)
Started by pfrattali, May 22, 2017, 07:26:40 PM
tinman
Quote from: jbignes5 on July 11, 2017, 03:53:19 PM
Sorry for the absence. I needed some time for local projects. Got a lot done so I feel better.
So for the arguments that a JT isn't a bifilar coil. Mheh.. Look at the the opposing winds. Just because it is connected differently doesn't mean that it won't have the same interposing wind rules that apply. An EMF moving in such a coil of one half of the winding will indeed reduce the cemf, in fact it should even increase in voltage because of the opposite polarity being shunted in between the primary winding. The core is to purge the magnetic field from the process which enhances the magnification. At least until saturation of the core then a leak happens.
I'm working on a very special coil setup that uses iron gardening wire with a bifilar primary and over wrapped solenoid secondaries. Two halves of the toroid iron wire circle will be used. A single channel, so two bifilar coils in series for the emitter coils wrapped on the iron wire toroid. This should allow disruptive discharges from a cap to an antenna as a virtual ground. The larger the antenna the more it can handle voltage before it breaks down the air around it and suck in free plasma from all around the antenna. The plasma should move to the antenna because the voltage acts like a vacuum to it. This should allow me to magnify the bifilar emf blasts as it (plasma) back feeds to the bifilar emitters. The secondaries should translate the emf blasts into AC which can be diode rectified into DC for storage and reuse.
Once the primary tank is filled it should run very happy till it wears out.
The secondaries I believe need to be of heavy solid copper wire and the secondaries will get very hot because of the emf blasts they are receiving. Later on cooling should be applied to the secondaries to keep them in operating condition. If large enough copper water pipe can be used and water pumped through the pipes to cool them.
My initial tests will be done as I build a grow light Led system. That will be my first test and will most likely have a battery involved to get the process started and keep the battery charged as it runs. Unfortunately you need a kick off run initially to get the process started. After the first run it should back flow into the battery and charge it up. I might need some circuitry to handle the charge back and cut off the power to the battery when it is charged enough. I should be able to use a current sensing resistor and sub circuit to handle that.
The small unit is already built and I should be starting my trials on the device. Digital meter and scope waiting to have some fun. As long as I start out slowly I should be alright. Give it slight power in the beginning and try to ramp up the power storage as I develop some graphene batteries I watched being built. This will make an excellent battery charger for those kinds of batteries since they are most capacitor like.
Also I am gonna be trying a few other things out with this setup including an interior rotor with self terminated coils and the effects of that related to Tesla's other machine I am going to be making.
I used some networking wire that is solid core but seems to be made of tin but coated with copper as the bifilar emitters. The one problem there is that it is fairly light gauge. I'll show pictures later.
If you look at a JT circuit there is indeed an interposing winding. That is just about the length of similarities to the bifilar wind or simply method. This interposing winding style separates the primary coil from itself and that kinda gets rid of most of the cemf. In fact I am thinking that this system could get gains via that fact, seeing that the negative is interposed to the positive wiring of the primary coil. Kind of like a speed boost only. So the current stays the same but the intensity or voltage level rise from the speed boost through the coil. With self inductance being somewhat removed from a coil where is this coil gaining the voltage then? The only other value you can change is the voltage really and that should equate to speed of the charges moving through the coil.
Tesla's other device uses the same premise. It's a motor generator with gen exciter built in. A magneto. All of that is turned via the motor or prime mover. The generator section has the same setup I am about to start testing with the Led driver. The emitter coils are bifilar going to an antenna. It is being fed impulses from a capacitor disruptive discharge circuit. That circuit is fed via the magneto exciter. The emitters are discharged into a heavy copper coil in the rotor which should generate huge currents in those coils. This will be split between the prime mover and load circuits and the rest if any is used to charge a battery or bank of batteries.
This device was patented by Tesla and only shown in vague details. The other patents Tesla released were used in that device. This is why we never really found any thing special about the older device. Every aspect was looked into by Tesla and I will be showing each patent and where it applies in the new device. This includes a magnetic Prime mover controller (motor controller), disruptive discharge circuits and many many other devices used to enhance the devices output. He was very smart about what he did. He put it all out there in the public's eye and no one really caught on until now.
For the meantime I will be experimenting withe this new disruptive discharge transformer setup. This is the heart of the generator portion of the device I mentioned above. Every aspect of the devices patent has been shown in greater detail in a bunch of individual patents with the devices patent being a way to put them all together.
Not all patents by Tesla were used. only a select group of them. I will try to post them all for everyone to see.
It is clear that you dont understand how a JT works.
The CEMF will not be reduced due to the winding configuration of  the two windings in a JT.
The only reason most JTs are wound like that,is for simplicity-nothing more.
Brad
A little story :
a.
the Aquino battery company got 190 Mio.US$ investment for the
exploration from a "saltwater battery".
The company became bankrupt,their total productive assets now
in sold for 2,8 Mio. US$. ( Mr. Bill Gates lost some soft earned money :'( sad,really sad)
b.
anybody here knows about William Putt and his patented ergo publicated work (?) :
double windings !
Why,the improvements now based by which experiments and results ?
c.
there was built a capacitive windings motor with a 40 KW power output,these has been coupled to a 40 KW(nominal) generator.
The investors wished to become the functionality of this
arrangement tested :
in a professional (animal food)mill this motor-generator should drive one of this mill devices, equipped with a nominal 20 KW
electric motor.
the 125000 Euro investment experiment failed,
the capacitors became destroyed.
So dear readers, a knowledge about each camper and traveller worldwide can tell and explain to you :
the inductive load needs for the start phase an heavy energetic input,the 5x,10x and by toroidal transformers up to
the 60x value from the nominal worth !
If someone shows to you that with a 3KW generator he/she/it can drive a 3 KW motor nonstop then there is a fake included !
a soft starter/inrush current limiter arrangement gives maximal a 60% inrush decrease !
tinman
Quote from: lancaIV on July 12, 2017, 04:02:36 PM
A little story :
a.
b.
double windings !
c.
electric motor.
I really do not think many here can grasp the fact that the winding/self capacitance is that small that it makes near to no difference in the devices operation.
Nor dose it seem to compute that the lower the CEMF,the higher the current rise over a given time.
This of course means more waste heat.
Like i said,if you lower the CEMF of an electric motor by say just 10%,you now have a motor that consumes more power,produces more waste heat--and it's not even doing any work yet.
You now place a load on that motor,the CEMF drops even further,the current rises even higher,and the waste heat increases even further.
So you are going backwards in trying to reduce the CEMF--you need to increase it for more efficiency--not reduce it.
Brad
citfta
You are absolutely correct Brad.  I went to the first energy conference that was put on by Rick Frederick and Aaron and that group.  When Peter Lindemann gave a lecture about how we had to reduce the CEMF on a motor I shook my head in wonder.  I never went back to another one of their so-called conferences.
If you want to see the same effect as removing the CEMF of a motor all you have to do is remove the governor on a small engine and hold the throttle wide open.  You get the same effect.  The destruction of the engine.
On a large DC motor with excited field windings you can remove the power to the fields and you have eliminated the CEMF.  You have also now got a motor with no torque and very high armature current.  If you can get it to turn it will accelerate until it flies apart.  I really wonder where the idea of eliminating the CEMF came from other than what I heard Lindemann say.  I guess that is where it started.
Carroll
tinman
 author=webby1 link=topic=17297.msg508264#msg508264 date=1499980845]
QuoteIf the used potential is only voltage then it is an electrostatic motor
First up,an electrostatic motor runs on both current and voltage-power
Second-there is no such thing as an electro!static! motor,as the charges are now moving,and so, no longer static.
Quoteif it comes from amps then it is a "conventional" motor
No
In order for current to flow,there must be a potential difference-->voltage drop between two points-unless you are talking about a super conductive ring or coil
So once again,both voltage and current are needed.
QuoteHow much torque does 10A make?
A question that makes no sense,and cannot be answered.
QuoteWhy do we need to keep increasing the voltage to maintain 10A as the RPM goes up?
Because of the CEMF/BEMF
Your motor is also a generator,that generates power that apposes that which creates it-->this is what reduces the current flow into the motor,as the motor gets up to running speed. If there was no CEMF/BEMF,then the current flow into the motor would be at the maximum value that the winding resistance allows,and/or what the power supply could deliver.
Clarification on opposition.
When we say !apposes!,that means that the motor is generating it's own power of the same potential as that which is supplied to it. This causes an !opposition! to current flow from the power supply,due to the voltage potential between the supply voltage and self induced voltage across the windings to decrease.
So,lets say you have a winding resistance in your motor of 1 ohm,and you drop 10 volts across that 1 ohm resistance. At the instance you do this(before the motor starts to spin),the current flowing through those windings will be 10 amps. As the motor starts to speed up,it generates a voltage across those windings that is of the same potential as the supply voltage. Now lets say your motor has reached it's half way point in it's maximum RPM,and it's self induced voltage across the windings is say 5 volt's. So the potential difference between the supply voltage and self induced voltage is now only 5 volt's. 5 Volts across 1 ohm is 5 amps.
Now your motor is running at it's maximum rpm,and the self induced voltage across the windings is say 8.5 volt's,and so the potential difference between the supply voltage and self induced voltage is only 1.5 volts. 1.5 volts across 1 ohm is only 1.5 amps.
So,startup power was 100 watts
Mid way to max RPM,it was 50 watts
And at max RPM it is only 15 watts
These are only examples,and the motor is unloaded.
But do you see why the CEMF/BEMF needs to be as high as we can make it,and why it should not be removed as being suggested in this thread by some.
So,the faster the motor spins,the more CEMF/BEMF it produces.
Quotemeaning that there is now a constant torque being made at whatever RPM.
Meaning you now have a big resistive heater.
QuoteWhat if that was from say 10V @ 10A being supplied, what happens when the RPS * torque exceeds 100J?
J? __> Joules?
Power is measured in watts,not joules.
So that is 10V @ 10A=100 watts
With ideal components,an electric motor would consume no power,but in reality,we have no !ideal! components,and so the maximum output power delivered by the motor would be 95% of the input power-at best.This would be a top end motor.
QuoteThere is induction in said motor as well as self induction in said motor,, what do you think needs to be controlled and what impact could that have on the mechanical work done by a motor with these things under control.
I dont think !controlled! is the right word to use.
The more CEMF/BEMF an electric motor produces,the more efficient it is.
As i stated above,an electric motor made from !ideal! components,would consume no power,as the CEMF/BEMF would be equal to the supplied EMF,due to there being no losses-such as winding resistance,bearing resistance,core losses-ETC.
Brad
