Testatika small machine testbed
Started by Steven Dufresne, April 21, 2005, 08:51:24 PM
Steven Dufresne
Hi all,
Back in 2005 I started work on replicating the Hyde generator, well documented in US patent 4897592:
  http://www.google.com/patents?id=HX4BAAAAEBAJ&dq=4897592
From private correspondance between William Hyde and Moray B. King (see King's book "Quest for Zero Point Energy"), a prototype that contained 2000 capacitors and diodes produced the following results:
  No. rotor segments: 240
  No. stator segments: 480
  Rotor speed: 6000 rpm
  Output voltage: 602 VDC
  Output current: 38 amps
  Output power: 22.9 kW
  Input power: 2.4 kW
  Net output power (while free running): 20.5 kW
Then I got side tracked for 3 years with the testatika (:-)), partly because of its similarity. Lately I restarted building my Hyde replication and given what I learned about the testatika over those 3 years I see the correlation even better. So I then returned to the testatika and am currently modifying it to match. I've documented the correlation, with a diagram, at:
  http://rimstar.org/sdenergy/testa/testatika_and_hyde_generator.htm
It's off of my theories page:
  http://rimstar.org/sdenergy/testa/theories.htm
Basically, it says that the interaction between the testatika disks and the antenna keys are where the excess power is being produced in the form of anomalous high voltage spikes and that the pots turn these spikes into lower voltage DC.
-Steve
http://rimstar.org
PS. Hi F_dyne. We really do seem to be in sync today. :-)
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
