Multisim shows once again overunity with differant setup 60.000 times ou
Started by indigo22, August 13, 2017, 10:42:51 PM
indigo22
i know this might sound weird to you but it works
even radiant energy flows from negative to positive  ;)
indigo22
@Tinsel koala kut
pleace leave this conversation
ok you cought me on a mistake if you don't even have the brains to know that 2 wires are switched
i think you should better leave
damn it's like kindergarden here
@ admin is there a secure place where only serious members talk??
indigo22
Your wattmeter is reading the power being supplied by V2 as it discharges through the secondaries of the transformers.
// bullshit thats what i said you don't know this setup how many time do i have to tell you the magnetic bias doesn't use amps
  In the real world the transformer would be burned to a crisp in a few seconds and the battery would also be discharged quickly until the transformers burned up.
// again bullsghit that's why we have a pulsing circuit disconnected from the capturing circuit and if possible disconnected from the magnetic bias
  The shunt in the wattmeter that measures the current is a dead short across the battery with only the secondaries of the transformers limiting the current.
// what the fock you talking bout now??
The OU of your circuit is about a minus 100,000 or .000001.
// if you can't calculate voltage and amperage i think you should better be going back to school
The pulses applied to the primary side of the transformer is only slowing the process down a little but the end result is the same.
//Dammit where did you study??? the pulsing of the primairie is to create a radiant spike witch can be collected by the secondairie
  Burned out transformers and a dead V2 battery.
// no we use micrometal cores and silveerplated copperwire with enough gauge, and again the v2 is there for a bias not to produce aMPS
  Picking the right frequency will actually speed up the process of destruction.
// no comment
indigo22
1.4 GIGAWATTS 8)
combine 2 4 x 4 transformers to simulate the tom van keulen v9 coil
i create 2 magnetic biases and 1 radiant pulsing trigger and a collector bias
check it
donwload file for multisim 14.1: https://www.free-energy-revolution.nl/app/download/10058952119/1.4+GIGA+Watts+multisim+free+energy.ms14?t=1502749732
