Gear pump and magnets
Started by Low-Q, September 08, 2017, 06:01:56 PM
Low-Q
I made a short video.
It does not measure anything, just showing the crancks on each rotor.
Both the inner and outer gear resist more one way than the other. Don't yet know how to interpret this simple test.
https://youtu.be/r9SBEiTe72g
Vidar
http://azbusinesslink.com/category/27077.html
You have to become di-/bipolar in thinking,
seeing things/objects from outside and feeling from the object middle inside to get the right,later by optimization, near perfekt result.
         That is LOGOS,logere :beiwohnen,inne sein ( become virtual  the objekt 4/...dimensional)
                                                 EINS-SEIN
         To differ from : habere= to have and habitare= to live(in)
Each programmer is doing this: The construction of an virtual "Habitat" for letters and numbers ,
and a 3d-c.a.d.-programm need such behaviour and mental manner.
                  inter-legere intel-legere inter-lego inter-lexi interlectum intelligente
                                  Einsicht, Verständnis,Illumination
                https://patents.google.com/patent/US6172941B1/en
You are well equipped with 4d-lab instruments and motivated : self-organize yourself
https://www.bing.com/images/search?q=xyz-koordinatensystem&qpvt=xyz-koordinatensystem
    "vidar",this Non-sense is about "Yourself" and humankind : NLP
                            Neuronal-Lingual-Programming
https://en.wikipedia.org/wiki/Neuro-linguistic_programming
                   Who program(m)ed you in all your live to become how you think "you are: .." ?
   The other google search links takes too much time to search through.
                              Begin with an " I am ....." listage !   ( under stress ?  ;D   :-\ ;)   )
Then think/decide what you call "non-sense",sem sentido= neither concrete nor abstrakt ={ }
                                                   no sound/recall
                                                leere Menge(-n-Lehre)
                                     https://de.wikipedia.org/wiki/Mengenlehre
                                     https://de.wikipedia.org/wiki/Kybernetik
                   sensitive learning :
http://web.archive.org/web/20071004041426/http://sensortime.com
I will leaving now your thread/theme but this points above are clearly for all threads and themes guilty and finally: Nobel-award,"asymmetry(is perfection,no end=endless)
https://www.bing.com/images/search?q=archimedes+hebel&qpvt=archimedes+hebel
                                    not only water related : the lever laws
                                                        energy R&B :TrueScale
https://www.bing.com/search?q=meta-c+dinnan+patent&PC=U316&FORM=CHROMN
Have a good,from me no more disturbted, time and well success in your live-life
        OCWL
Low-Q
IancaIV, if you cannot contribute to the topic, please stop posting nonsense and links to something that has nothing to do with this topic.
Thanks.
Vidar
Low-Q
Today the axle that holds the inner gear broke off. I was playing a little too hard.
I need to find ball bearings that have 13mm outer diameter that fits inside the inner gear. I have one, but need more to fill the hight of 12mm.
Then I will build a more solid construction with small ballbearings supporting the outer gear, by placing them outside it. I cannot come up with a better solution to make a smooth and controlled spin.
I also must grind away a tiny mm from the inner gear so it is more space between inner and outer gear.
Plan B is to use iron powder soaked in epoxy, that is filled inside 3D printed molds. I will search on ebay for fine iron powder.
Plan C is to use sintered iron powder cores I used to use for inductors in speaker crossovers. I have hundereds of them in two different sizes. Maybe those will do the trick.
I do not give up intill I have confirmed what causes the difference in counter torques ccw and cw.
To be continued.
Vidar
