Homopolar with only permanent magnets, and no battery?
Started by Low-Q, September 20, 2017, 03:02:09 AM
Low-Q
Hello,
For learning purposes, I have done a simple test with two doughnut magnets, polarized through thickness, and a long magnet as shown in the image "Equal and opposite torque".
The long magnet is forced to the right, but there are no sign of forces acting in the two doughnut magnets to make them turn around.
Reason is assumingly: When the force of the long magnet goes towards right, the long magnet also want to turn clockwise. This is an experiment I have done physically. Nothing happens to the round magnets. No spin, no torque. This is the only experiment I have done this far, on this particular setup.
So I think I will try to replace the long magnet with another smaller (approx half diameter of the larder ones) doughnut magnet that has one side polarized opposite, as shown in the image "What happens here 1".
The experiment will show me if that smaller doughnut magnet behave just as the long magnet, but if it will turn counterclockwise instead since it is on the inside of the larger doughnut magnets, AND wants to be forced to the right, just as the long magnet do - so the total forces points in the same, and not the opposite direction, to achieve torque. I want to learn why this possibly cannot work.
This is a test that will confirm what happens when we try to make a homopolar style motor with only permanent magnets.
A homo polar motor is basicly a conductive permanentmagnet attached to minus of a battery cell, and attach a wire between the plus and the magnet circumference (which is connected to minus via nickel plating on the magnet).
The magnetic field in the wire is circular and affect the field in the magnet so it will try to escape perpendicular to the circumference. This results in a rotary motion of the wire, or the magnet, depending on what style you make.
I will try to make a similar circular magnetic field between the two larger doughnut magnets, see image "What happens here 2". Since the small magnets curve away and inwards towards the hub, I want to check out how this will affect the forces, or possibly torque in the system.
Is it possible to achieve rotation with an all permanent magnet homopolar motor?
I think not. Possibly a waste of time, you might say, but I want to learn  :)
Green arrows are assumed forces if not specified otherwise.
Vidar
Low-Q
Here is a screen video taken from SketchUp Make. (I came across a function in Windows 10, which has the X-Box app. Pressing Win+G opens a recorder panel, and recorcds the active window :-))
https://youtu.be/wImS70Hqu0E
Vidar
Low-Q
Quote from: lancaIV on September 20, 2017, 07:06:03 AM
https://peswiki.com/directory:magnetic-motors:pm3
they deliver probably functional help and advices
wmbr
        OCWL
No pictures. When I click on any bla-bla-bla.jpg link, I enter a site with a million links. I cannot maneuver through all the links.
Can you provide a more specific link I can click on so I can go directly to the correct site?
Vidar
Low-Q
I found the inventors website by google the name on one of the image-links.
http://mmmgroup2.altervista.org/e-magnet.html
Looks interesting. I have hundereds of neomagnets, and iron washers for the iron cores.
Forst an accurate simulation in FEMM. I suspect that the simulations made by the inventor are some what coarse. That will provide inaccurate data.
Vidar
