Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
sm0ky2
The latch-pin is a nice addition, as it release the ball when you need it to
vikram_gupta11
Dear Sm0ky2 Sir,
See the sketch.as per sketch the tube length is 2 meter.
It is mounted in middle with left arm.
A10 kg.ball is in rest position in this long tube  below 1 meter from fulcrum.
The counterweight is 20 kg.
I have taken a ball as a counterweight in a 1 meter long tube.
The long tube rest 1 meter part is above fulcrum.
Now as per my calculations input and output.
If seesaw is in horizontal position and ball is in rest position below 1 meter from fulcrum then counterweight will be 14.4 kg.
But I have taken 20 kg counterweight.so seesaw will be in Vertical position.
Now input will be 100 Joule
As ball will be lifted up only 1 meter.
But output.
At first ball will fall down from 2 meter height
So output=200 Joule
Ball will again fall down from 2 meter height
So output=200 Joule.
So total output is=400 Joule
But there is more output from counterweight.
When ball will hit the top of tube at the time of tilting then the counterweight ball will also jump in the tube and it will again fall down.
If 20 kg.ball jump 75 cm in the ball then the output will be 150 Joule.
So total output will be 550 Joule.
There will be a great advantage if counterweight ball jump in the tube as device will get great momentum.
vikram_gupta11
The device get great momentum if counterweight ball jump in the air in the tube as the counterweight will become massless up to that time when ball is in air in the tube.
In this way the counterweight will also work as a output.
vikram_gupta11
I did an experiment to know the feasibility of device .when I drop the ball then the counterweight ball is bouncing in the tube to provide leverage.
This experiment is proving difference between input and output.
sm0ky2
Only as an oscillatory device.
When turned in a complete circle,
The energy gained in the top half is lost at the bottom.
also the balancing seems important, it needs to be heavier on the
counterweight side, so at rest, the ball is above the axis.
otherwise, the effect is mostly lost.
But when it's too heavy, the down-motion of the ball is fighting the
counterweight.
Still working on a demo model, it looks like the arm with the weight
should be angled, opposite to the angle formed by the end of tube to axis.
this way the machine can balance with both weights at the axis.
