Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
What you can do is tap the earths electric spin field which is unbalanced the unbalanced spin and volia!
This has to emulate the earth it self with the device and then tap into the earth and now you have power.
We all know how to extract energy from the earth so you will need a accumulator so the incoming energy gets stronger and stronger due to current electric draw because the earth gives you little power to begin with so with this little power from the earth we use accumulator to suck in more and more energy this is because it is already tapping into the earths energy field so the thing that causes it to suck a more larger amount of energy comes from this little energy from the earth.
So we use this little energy to attract even more energy with no end in sight and the earth which has it's unbalanced spin so it will keep on running with real power and torque so yea thanks to its unbalanced electron spin, unlike a cemf electron spin this is a different breed.
due to the earths unbalanced electron field an accumulator will behave as i stated by sucking ever more energy from the energy we already harvested from the earth so it will be self starting then.
Not radio waves if it says 7.8 hz then it certainly is coming from the earth.
The energy comes from the earth so yea people will say it is perpetual motion but it isnt and wonder where this work/power/torque is coming from and that is coming from the earths unbalanced electron spin.
So yeah first off the earth's electric so to speak and then get an antenna to tap this electric and it will be a low amount and then use some accumulator to cause it to suck even more energy out of the earths atmosphere by using all the electric you already got from the earth so it will be closed loop since it will suck even more energy in from earth and the very thing causing this to happen is you guess it the unbalanced field of the earth which is most important and this sucking process just attracts more energy from the earth because in simple physics negative follows positive so it will work because you are using the earths main engine the unbalanced electron spin, and it will work because it is already proven regarding the main engine of unbalcned force is in the earth it self and if it wasn't the earth would stop working spinning in fact because if the spin was balanced like everyone knows it will be at best a cemf electron spin where it spins but you cannot use the power, whereas the earth has real power in the instant the unbalanced spin it has is where it is at so thanks to this we can use electric from the earth with torque to power a load.
Simple enough what i typed here will work.
So yea use all of the extracted energy from earth to power it self so it extracts a never ending stream of power as it attracts more and more ions.
Proven because positive sucks in way more negative in an unbalanced fashion because the earth has those unbalanced force.
if the earth didnt have those unbalanced electron  spin the earth will stop spinning so the torque comes from the unbalanced electron spin and you can use/emulate the unbalanced nature of this and there you go free power.
people build a magnet motor which follows the balanced electron spin so the magnet motor will spin as that with no power/torque so use earth instead with its unbalanced force and call it a day.
So all in all using the earths power/torque to power the device it using to extract ever more.
from
https://peswiki.com/os:calloway-magnet-motor
Theory
Index of scientific modeling and supporting documentation to describe the physics of the process.
Harnessing Electron Spin
Robert H. Calloway said: "It is actually harnessing electron spin that drives these engines." He also said: "The magnetic gate is the holy grail to a successful magnet engine."
So yea when u extract the energy from earth the positive and negative it's self will be unbalanced as it auto tunes to the earth it self.
Maybe use a rectifier?
Something like this > https://www.nuenergy.org/prentice-electrical-power-accumulator-patent/
Using the extracted power to power the antenna that drags in ions from the sky like an amplifier.
There are some antennas shaped like a can which can reach miles in the sky to drag the positive ions i think from the sky.
I think using the ions alone with there attraction and repulsion will be used instead of normal electric powering an antenna that way it will work.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
With some kind of bridge rectifier.
lltfdaniel1
Out of all I said about energy from earth it will not work but demonstrate the driving force which needs finding and other methods to work fully though and I see it will fully work.  Methods that use the unbalanced force of the earth so it is like an invisible motor. Maybe some switching technique but I do not know but passively having it run without switching as the earth already does that for you. I see it like this it is like a badly optimization motor regarding the unbalanced force of the earth regarding what I have said, it jolts with power and then stops so it needs tuneing so there is full power coming in. There are different ways of controlling this invisible unbalanced earth motor so it will speed up or down with real power. The earth already has its own speed controller otherwise the earth would spin faster or slower with real power.
lltfdaniel1
I am dead correct about the earth having real power other wise wind turbines etc from the earth wouldn't work so simple enough. Especially with the unbalanced force which it where it all stems from. I would love to know the centrifugal force about the earth's unbalanced power that I am on about so it is easier to work out how to get this vision of mine to work fully.i view it as this the earth has its own control panel regarding the unbalanced force you know to speed up or down regarding the earth's rotation andnthus can also be done in a devices tapping into the earth's unbalanced power.
Thereticly this will work in reality for one the heat pump has no limit in how much it extract same with the earth's unbalanced electron spin but is not perpetual motion but the force it self is like that though so I repeat it isn't perpetual motion.
I can see the device working with power at a constant rpm speed regarding the earth motor.
lltfdaniel1
All done by the way the earth does it.By emulating the way the earth's does it.
