Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
So yea with virtual invisible motors and stators like that patent you will also have an invisible unbalanced motor as well to use that is so it is included.I think it is possible that whoever uses my idea will eventually succeed. It needs a partical accelerator for it to be unbalanced with the energy that is ions so it will be a power draw with that you know my ion attraction regarding electrical current flow so positive is unbalanced with partical accelerator so it gets bigger and bigger. Like with electric positive follows negative so with the particle accelerator it will work as I stated so it is self powering like an amplifier but with natural ions. As have said so you know what I am on about.using partical accelerator to attract ions from sky so it self powers grabbing energy with no end in sight. With particle accelerator it is now possible to attract even more ions using then ions to do the job with no end in sight as it the particle accelerator is self powered by ions it already has even if it little power regarding ions it will work in that fashion.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
That is the heart of the process partical accelerator. Get that to use little energy to attract even more energy in unbalanced factor.
So yea we get milli amps of power from the earth, all you have to do is use a particle accelerator and have it designed so it uses this little power to attract even more ions so it can be called an ion electric pump.
The speed gets bigger and bigger that is what we need and the partical accelerator delivers on this one with more and more ions more and more current and volts sucking it all in.
The amount of ions determines the extraction speed thus is controlled in this way and has to go with the flow of ions being extracted so it is now possible to use this method because you couldn't do it with a normal electric circuit but with this overcomes that limitation.
The particle accelerator needs to be modified to work in this manner and I can see it will work.
lltfdaniel1
The particle accelerator goes with the flow of ions being extracted and also over comes the limitations of using extracted ions as source. So this particle accelerator bypass this problem and you can't do it with a normal circuit but with partical accelerator you can. Needs to be a modified particle accelerator so the extraction is and will be unbalanced. How well am using single current to fully overcome that. Because the partical accelerator controls how fast you extract which is what I need. With this idea of mine which is extracted ions using ions to power the particle accelerator to get even more ions and you cannot control extraction speed with normal parts.Other wise it will be too slow and is clear it won't work.
You can use particle accelerator for speed extraction as well it has the speed to be fast enough with switching. Instead of transistors the particle accelerator blows that out of water.
lltfdaniel1
Why particle accelerator well it is to do with a orderly fashion of self oscillator regards the particle accelerator extraction speed and be controlled with an unbalanced flow of energy.
You can't control it like that with a normal circuit, if it is too slow it will miss on ions being extracted.
lltfdaniel1
It's th the inerea of particle accelerator makes things like extraction much better among other things.
It can be used to have bigger range of distance as well to extract like miles up in the sky finger more ions etc.
