Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Because of lenz law it has to be tapped. Unless the earth has its own process to overcome lens law I don't know.
I think the earth does bypass lens law and the speed of particle accelerator speeds up the process as to how fast it will naturally extract energy.
I need this natural process to be known to exploit it.
To auto tap the energy done by earth's natural method with self oscillator and to take advantage of this.
The tapping will be done with the particle accelerator antenna.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
No tricks this is possible.
I am after a continuous amount of energy as in power done by the earth regarding continuous  rpm with power torque by limited by the earth so the earth does all the work as in bypassing lenz etc or get some rectifier to amplify the energy i am no longer speaking in layman's terms heh.
I want my particle accelerator antenna https://www.google.co.uk/search?q=particle+accelerator+antenna&safe=off&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwihv8T89OvWAhWCRBoKHcLPD8YQsAQITg&biw=2560&bih=1309
Also i need a circuit that is designed to take advantage of the earths power/torque regarding those spins other wise you need to tap the energy but i want the earth to do that though so i don't have to bother and will work again.
lltfdaniel1
Maybe an earth stator coupled with the particle accelerator antenna.
lltfdaniel1
Like this using extracted energy to power the energy extraction process with power to spare that is what i want in a circuit regarding all i have said so there is no limit but lenz law will be there biting into that prospect.
So yea i want to do that after all i said regarding the particle accelerator antenna and the like and i think it is possible because the earth is wired for it and needs to be designed for the earth as in its limitation of power the earth actually gives in regarding it spins and also me saying it will be limited rpm with power as have said but i want to extract like the heat pump but with this energy from the earth to extract without end but there will be limitations and i think the earth it self will limit that as well.
That is all.
Using the earths own torque/power to power even more extracted energy without end, i think is doable.
Whoever uses these ideas will succeed out of my posts
lltfdaniel1
So yeah the energy extraction has to be unbalanced and the.earth has this process built in all you have to do is tap it.
You have got to find the earth's way of overcoming lens law for it to be unbalanced as well as the circuit you will be using.
Maybe an open circuit using the earth doing this unbalanced work.
Cold circuit well that is the earth's own built in method so you don't have to work that one out.
Instead of it getting hotter it will go the opposite it will get colder instead of getting hot like the same with mostly all electronic circuits for this to work with the unbalanced force of the earth.
A conventional circuit will kill the unbalanced force coming from the earth that is.
