Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
I can see a rod in the ground with the entire circuit drawing in power that is unbalanced and is causing the circuit to get colder and colder this is extracting energy as have said in my other posts and is accomplished and now the circuit has the unbalanced force or power or torque to do work.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
From solely all work being done by the earth.
The earth has this cold process regarding giving your circuit getting colder not hotter.
I can see that it is cutting off the process because it wants to get hotter and hotter. The earth has its built in cold circuit so you tap into this cold circuit of the earth.
Simply copy the earth method and in any case with it getting colder it has bypass the limitations to get it to run off the extracted energy and using extracted energy to power the extraction process with energy to spare from the extracted energy.
Some thing about a double vortex the earth has them so yea double vortex to tapping into the earth's own cold circuit of double vortex  but am not sure about this, I need proof.
Something like two rods to take advantage of the double vortex so that is unbalanced
A parallel circuit is key to all of this as well so design a parallel circuit so that the current draw is unbalanced to give real power regarding all I have said I now know that to accomplish my idea is done with a parallel circuit.
I think I am wrong.
lltfdaniel1
I can see with a parallel circuit it will overcome all limitations as to what I need in this earth circuit.
I know that if you want to overcome lens law then it has to be a parallel circuit.
lltfdaniel1
Yes the parallel circuit is where it is at. Instead of tapping use a parallel circuit.
I think you need to configure the parallel circuit so it doesn't kill the unbalanced force so you will have power for sure and but makes sense to me that this is accomplished with a parallel circuit.
So yea it won't kill the process  that will make the circuit cold.
lltfdaniel1
In fact the parallel circuit is critical for this to work
After all the post ideas etc i now know the last piece of the jig saw is a parallel path circuit, it will extract energy within the parallel path circuit whilst overcoming lenz law and have said there is indeed a driving force in the earth that does real work so it will work in that fashion.
It will be an open circuit regarding the parallel circuit so it can do it's magic to make this a reality.
So yea a particle accelerator antenna so it self- amplify it self to suck in ever more ions/energy and then the parallel path circuit to overcome lenz law limitations so all obstacles are out of the way leaving you with extracted energy and a bridge rectifier i think that's most of the parts.
So using extracted energy to power the energy extraction process with power to spare.
So this energy is free to return back to the earth and thus you have completed the process, as in getting this device to run of extracted energy self powering it self with energy to spare so there and i can't stress enough the earth has an unbalanced electron spin so that means it will work in that fashion.
So no more jolts of power no need to tap it just use a parallel circuit instead so it will be a constant jolt of power.
Regarding parallel path as there is different breed of parallel path i mean this translated into a circuit with the link below this sentence.
https://peswiki.com/article:joe-flynns-parallel-path-magnetic-technology----by-tim-harwood
The methods of over coming lenz will be in that link.
Well i know it is possible to get what i need that is for sure even though that is about magnet motors.
I think this link here is more up my street > https://pesn.com/archive/2006/03/05/9600243_Bearden_MEG_Flynn/index.html
All in all i need a modified parallel path circuit extractor like the antenna which i call the particle accelerator antenna.
Principle of the parallel path will be there i just need a mainstream science one to overcome this i think exists somewhere like the same way i found about the particle accelerator.
Actually what i am looking for was this all along > https://www.homemade-circuits.com/2014/02/can-parallel-path-magnetic-technology.html yea what i was looking for you see that magnet has 4 units of strength this is unbalanced and would work nice with my earth circuit and especially the particle accelerator antenna.
Clearly that is extracting magnet energy so what i need is for it to attract ion energy and is parallel so it will return the energy back to the earth without cutting it off i think, well basic principle but i think it needs to be modified with this idea.
Yet i think this conflicts with my idea about the particle accelerator antenna.
Well with the particle accelerator there is 1 path but i need 2 so it is double so it over comes lenz law and all of these limitations.
Correct me if i am wrong but am getting brain dead here.
