Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 293 Guests are viewing this topic.
tinman
Ok,decided to play around with the energizer a bit more.
After some trial and error,i found a cap value that raises the output voltage of the generator,and also charges the 10 000uF cap faster,to a higher value--but still slow.
But it comes at a cost.
When the cap is added across the output to form the tank,the current draw to the prime mover go's up another 86 odd mA.
So,where we gain in one area,we loose in another.
First scope shot is without the tank cap.
Second scope shot is with the tank cap across the output.
Third scope shot same as second,only with half wave rectification.
Brad
Void
Quote from: tinman on December 05, 2017, 06:26:13 AM
Hi Brad. Yeah, maintaining LC resonance puts more load on the driving part of the circuit, in normal
circumstances anyway.  To see an OU energy gain something very out of the ordinary will have to be
happening somewhere.
I have been running tests on battery pulsing in various ways to see if I could find any unusual
battery charging effect like Tom Bearden has theorized about, but so far I have not found anything
that looks really unusual. The alternate pulsing of the motor drive and cap discharge with the use of a
sizable flywheel to keep the generator spinning up to speed during the cap discharge pulse window
is one possible source for getting an unusual gain, but of course you have to be able to get the cap bank to charge up
to at least 2 or 3 volts above the battery terminal voltage in a suitable amount of time first before trying the alternate pulsing,
which is where you seem to be having an issue.
The problem with trying to replicate other people's setups is most people who claim and demonstrate OU devices typically do
not provide enough specific details to do a proper replication. I am skeptical of John Bedini's claims because, that I know of, it seems
he never demonstrated anything publicly that really convincingly looked like over unity. As most people no doubt realize, doing relatively
short demonstrations when powering with batteries can potentially be very misleading.  When powering with batteries you have to do relatively
long test runs to see how the battery can really hold up, but this of course depends on the capacity of the battery you are testing with.
I try to keep an open mind however. Maybe there is something unusual hiding in Bedini's setups. :)
All the best...
Grumage
SkyWatcher123
Hi grumage, thanks for sharing.
I thought the battery was supposed to be conditioned for this setup to work, is that motorcycle battery conditioned.
peace love light
