Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 25 Guests are viewing this topic.
wattsup
Quote from: tinman on November 12, 2017, 10:15:10 AM
Well thats not very good math Wattsup.
So now the generator wheels are 1/4 the size,but we have 4 times as many.
This means--no loss/no gain.
You just made 3 left turns,and ended back where you started from :D
@tinman
Wrong. This means you can now load those generator coils and the true full leverage of the flywheel can be used to cut through the drag generated. No drag no output. It's just a question of where do you want to fight the drag, near the shaft or on the outer edges. The full rotational energy is exerted on the central shaft, not on the outer edges.
The other misnomer in his design. Generator coils in series will produce high voltage. But to keep the battery charged, anything above 14vdc and 20% of the battery amps rating will be wasted because the battery simply cannot use it. High voltage low amps on the battery will just eventually render the battery a reactive source that will have no or little amperage available and eventually die.
The first thing you need to do on such a project is to produce a battery baseline otherwise you are just winging it. Use a standard trickle charger and charge the battery until it shows charged at xx volts. Then run any 12 volt device with the battery and see how long it takes for it to fall to 11 vdc. Never let the battery go below 10.5 vdc. Then run your bedini thingy until the battery reaches the same charged voltage level which will be very quick with those high volts. Then do the same DC load test and see how long it now takes for the battery to fall to 11vdc. You will see that the later will take minutes. The bedini farce is thinking reactive battery charge has value, but it does not.
Once you do that, you will quickly realize that those generators coils are better off stay all in parallel or some in series to get the 12-14vdc charge voltage then those sets paralleled to increase the amperage charge. That will balance out the system to be totally complimentary to battery.
wattsup
Grumage
Quote from: Erfinder on November 12, 2017, 07:16:08 AM
I responded out of respect,  you are aware that Tinman does not want me posting here....so....I hope I answered your question....  I will be respecting his wish from here on out.
Thank you for your curtesy, and the mention of the magnetic offset.
Redward
Looks that acceleration under load is coming back. Thane Heins has replicated one of romerouk old generators.
romerouk version
https://www.youtube.com/watch?v=p7e6Lu_YSCo&t=222s
Thane Heins Oct 2017
https://www.youtube.com/watch?v=X1vQ7t3A9oc
Void
This is the Youtube video made by the guy who said he got his build based on the Watson motor
to self run:
Bedini Machine aka Watson Machine
https://www.youtube.com/watch?v=mdiK8sb81XU
From what I understood, he said that once the motor was up to speed, he switched out the
start battery and he said the device was powering itself and charging the battery at the same time.
tinman
Quote from: Void on November 12, 2017, 12:55:47 PM
to self run:
So i wonder what happened,as that was back in 2012.
I also think we can get the machine to run a little smoother than that one.
I see a lot of voltage measurements,but no current or total P/in P/out measurements.
There is no follow up video's after this one on his channel,so i suspect that it did not end up working as he thought it was.
Brad
