Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 308 Guests are viewing this topic.
tinman
 author=Void link=topic=17491.msg512984#msg512984 date=1510482843]
QuoteHi Tinman. If you charge a smaller capacitance cap to a much higher voltage, it still
takes current over time to charge that cap up. The higher you charge a capacitor,
the longer it is going to take to charge up unless something unusual is going on.
It wouldn't hurt to experiment with different total capacitance bank values though to see
what the impact is on performance.
Yes,i understand that,but a smaller value at a higher voltage would see more of the stored energy delivered to the battery.
I have three phases on the gen i am using,and so i can split each phase into pieces,and give us 3 different working voltage's,and so,we can try various size cap banks.
QuoteBatteries are weird because they are electro-chemical in nature and I think
in some cases their weird behavior can sometimes fool experimenters. However
if you leave a setup running steady for say 48 hours or so while drawing say 35 Watts or so
from the battery, and the loaded battery terminal voltage hasn't dropped at all, then you
may really have something. It is when people do a test run for less than 24 hours and then
also measure the unloaded battery terminal voltage and that sort of thing that can
lead people to draw wrong conclusions. :)
Oh yes
I am well aware of batteries and there tricks.
QuoteI'm not sure what you meant in your other comment in regards to having an open mind.
I have an open mind or I wouldn't be experimenting with this kind of stuff myself.
I just mentioned some ideas on how to possibly reduce wheel spinning. :)
Anyone is free to experiment however they like... IF some people want to try to replicate
setups where they don't have all the details , that is up to them. ;)
I was referring to myself.
Years ago,i was all for the free energy stuff-back in the days of IAEC.
Over the years,things never turned out like the claims being made.
And over the years,you start to learn what is rubbish,and what is true.
So i guess you could see that now as me having a closed mind,and maybe it's time i stepped into things again with an open mind  :)
Brad
tinman
Quote from: Erfinder on November 12, 2017, 05:54:17 AM
your common sense, and years of experience should have you answering yes to all of those questions...
I assist how I choose to assist....you don't get to dictate how I share and communicate my perspective.  All the schematics one need are already in the public domain....the problem is, authorities and those who label themselves authorities see things at face value, what you see is not always what you get....  for the record, I know as much as the next guy about what John had....I came to my own conclusions after "considering" what he said, and what he didn't say.
There you go again, jumping to conclusions.....  things are not as they seem...
See this is when it helps to be a fanboy rather than a debunker....  The prior, knows the goal, and works towards it, using what was given to discover the missing pieces....  shooting in the dark (trial and error) are the tools of the ill prepared, the lazy, the debunker...
The funny thing about your statement here is you think you are informing me of something....you aren't....as the story goes, watson copied bedini, eventually bedini perfected the design, miniaturized it, passing it off as a novelty.....got the public intersted in it...protecting the idea, preserving the concept.... this went on for 20+ years....  finally, he scaled it back up and presented the scaled up version in 2010...  a fundamental change was introduced, namely, the SG was married to the Kromrey, with the SG operating as both an energizer and prime mover, while the kromrey operated as a generator and motor....  wrap your noggin around that one.......
How about brainstorming what the damn thing was supposed to be before you begin anything, and drag folk along in your wake for the ride of their lives which, if it continues the way it's going, will lead to another bashing of the inventors work, not because he failed, more like the replicator failed to appreciate the inventor's vision...
The prime mover, the flywheel and the energizer must become one.....  comprehend the concept, and then mirror it, nesting one system within the other, forming something likened to a fractal.... just like he did....
Ok Erfinder--this is not the thread for you.
You are just going to be the same old Erfinder,where we have pages of nothingness from you.
This is a thread where people will post links to vital information for each other--not just say that the information is all over the net--not good enough.
So no,this will not be a thread full of your nothingness and riddles.
So please,refrain from posting here.
I have asked nicely.
Brad
Grumage
Dear Erfinder.
A few posts back you mentioned an " odds even " relationship between the energiser rotor and stator.
Most pictures on the web seem to depict an " even " relationship.
Was this something you developed or found advantageous from your early experiments?
Cheers Graham.
tinman
Quote from: Erfinder on November 12, 2017, 07:16:08 AM
With regards to the SG, everything  is even for the most part....  we never see Bedini actually do an odd even setup, we assume he had one when we research the Watson machine....assuming the attached image is a photo of the Watson device..   Look carefully at the magnets and see that they do not align with the coils.  As I stated before, you can engineer an offset within an even system, however, it's more complicated....
Other researchers, old men when Bedini was young, were exploring and or investigating odd versus even.  Check muller and adams for more information.
Offset in an even system yields superior results to odd versus even systems, that has been my experience.
I responded out of respect,  you are aware that Tinman does not want me posting here....so....I hope I answered your question....  I will be respecting his wish from here on out.
If it is going to be responses like the above Erfinder,then please feel free to do so.
Brad
stupify12
Tinman,
Go for it! learn from trial and error while working with your device.
I would go for the Hi amp charging the battery. Buck-boost converter for conventional approach.
I think its better to use the dry cell battery like Tesla batteries.
We look forward for the big flywheel device you are making, don't listen to others,see for yourself what results you get from your build.
Will
