Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 156 Guests are viewing this topic.
Gear
Quote from: TinselKoala on July 27, 2019, 06:57:09 PM
Hint: If my video is in the "alt.snakeoil" category you can be sure that all is not as it seems.    ;)
In this case you may recognize the wireless receiver from other videos where I demonstrate and explain. So even though it is not evident in the video, you could probably bet that a wireless power transmitter is somewhere nearby. Running under water is no trick, even though the water is  normally a short circuit, at high frequencies it has a high impedance so does not affect the lighting of the bulb. The behaviour of the bulb, brightening and dimming, is also a big clue.
Don't worry, if one of my videos isn't in "alt.snakeoil", it is totally legitimate.
No other word than Thanks!
I like your work! And passion towards it!
ramset
still under moderation Huh ?
Gear and others reading here .re: Mr.Koala's movies ,
at all times he invites scrutiny and provides documentation to expedite
the scrutiny of his measurement protocol and results.[itsu works this way too and others here]          There are other times its just for fun and not about any particular Query [or claim] but In my opinion always towards a better understanding of what "might" be possible....as of this writing ...I have never read or seen similar from RF or his mentor..or should I write
Begging scrutiny of a well documented presentation for an energy Audit
Mr.Koala is a Metrologist .and Practices Brutal honesty [the scientific method with 100 % transparency... so none can dispute unless they too show there results and explain ....not just one mans opinion. Chet K .PS I apologize for the bunched up text and lack of sentence structure in my posts at times ...this forum seems to smoosh and rearrange all my text together unless I use another method to post here. I attribute this to Hackers who have boasted here before ,and their stance against open source .
Thanks Grandma
Quote from: Grumage on July 28, 2019, 06:37:04 AM
Hi overcurrent.
I'm pretty sure most of the older hands here cut their teeth on " Bedini " tech.
One member, currently under MODERATION, Hoppy carried out exhaustive battery analysis over a very long period of time, he'd be the one to help answer your question.
I built several motors over the years, one ran for around 3 months, single battery and mechanical commutation with no " apparent " loss. Very efficient but otherwise, useless, as no extra energy could be had without upsetting the fine balance.
Not wishing to deter you in your endeavours, tinkering and a " hands on " approach is a great way to learn about this fascinating subject. Don't forget that there's many here that have already " beaten " this path, quite thoroughly, don't be afraid to ask questions.
Definitely, " Solar " is a good investment, I've just passed the 0.9 MWh in three months!!
Cheers Graham.
0,9 MWh  ::) : 20 sqm solarpanels with 10% average conversion efficiency  ?
900 KWh / 30,5 days( month) /3(months period) / 0,5 KWh ( daily max.  per sqm by 10% eff.) ~ 20 sqm
actual solar panels industrial price - fob Ningbo factory, in bulk- : 480 US$ for 20 x 133 Wp  8)
I spoke 3 weeks before with an engineer( Ex- Phillips development center employee in Liverpool and later Paris;with many international publications  ,working actually  as docent/Prof
for the Uni Braga) ) about silicon solar panels.
He said this technology will become " dead" ! ( I do not think so, disagree!)
In development " graphene thermionic cells", calculated R.O.I. time : 3 years  ;) ( okay: 60% eff.  :) )
The Dr.Reichelt( G.D.R. development)  graphit heat-electric cell ( from 1982 )with 80% conversion eff. was him not unknown.
European research cluster : University Aveiro/ PT.
overcurrent
Hi IancaIv
I am off topic here but I must ask seeings I just did a project investigation recently on a solar project. The proposal I got from a few different installer companies was 1.1 million dollars with a 300,000.00 dollar rebate and it came to a ROI of 13 years which you can imagine it didn't management long to shoot that proposal down because they are looking for a three year payback maybe 5 if it looks good in the publics eye so is there a website where I can keep an eye on this technology I would definitely look into it with that kind of payback thanks.
ramset
LancalV
Nobody throws away a perfectly good horse .
And that will probably make all the other panels  out there much less expensive to obtain and still very useful .
Here I must add !!
A few faces may be new here to some members .
Poynt and Vortex 1 (ion at other forums)
These fellows and others here, have drastically  moved the bar up for the talent in this
Open source venue.
Spending tremendous amounts of time teaching and explaining how to take proper measurements to get good results and also how to present your findings so as to be understood by the largest group of readers.
TinselKoala having dedicated tons of time and effort making teaching videos
And they hunt to for this elusive beast ...which some claim to have cornered but will not share
Open source ,
and yes they are very suspicious knowing all the Ways errors can be made ...unknown attachments to mains or grid voltage ..Unknown feedback loops  from equipment ...actually supplying the energy unbeknownst to the claimant ...Or Ground loops as a source to main grid voltage or couple to mains voltage and create scenarios where the energy is harvested and unknown methods ?? capacitive coupling ???
or other sources of energy which have nothing to do with OU .
Tinsel  has shown many times all the ways you can fool people if you were an unscrupulous individual or even at times persons unaware innocent of their measurement error
If open sourced... those results would be revealed as the  measurements Error they are ( only referring to errors made unaware here ) .
And make the experimenter the wiser and the community too
and make us all better at this task ,the hunt for Free energy.
Respectfully
Chet
Thanks Grandma
