Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Void
Quote from: a.king21 on July 30, 2019, 10:47:28 PM
Assuming each red led is ...
Hi a.king. That is exactly the problem, as you should be fully aware of by now.
You simply can't make assumptions about input power and output power.
This is something which has to be measured properly.
Also, the fact that Stefan says that he thinks you need a battery in there for the system
to 'work', is another potential warning sign to me, because if it doesn't work with super caps or ordinary caps,
then that seems to indicate that the current draw from the battery may actually be higher than is being assumed/stated.
At any rate, all these assumptions about LED power consumption is very counter-productive.
If people are afraid or can't do proper power measurements, at least power some 1 to 3 Watt incandescent bulbs
instead, and then see how the bulbs light. Any demonstration with LEDs is just not at all helpful, as I
pointed out several times already that they can be very misleading and tend to fool a lot of inexperienced people, as
they can glow quite brightly while actually consuming only a relatively very small amount of power.
Any demonstration using LEDs is really of no practical help at all.
Void
Quote from: rickfriedrich on July 31, 2019, 12:15:37 AM
You guys are just against OU.
Hi Rick. That is just plain silly. Actually, members here who have a lot of experience at analyzing circuits
have made it clear that without proper measurements there is just no way to really know how those circuits are
actually performing. Really though, there should be no reason why these setups can't be self-looped, as that
is a no nonsense test which separates the wheat from the chaff.
I can tell you this. If I had a setup which I thought was showing OU, I would 100% try to self-loop it.
I would do this because I am actually interested in knowing what the actual truth is. It really should be relatively
simple to setup, and you have said yourself in one of your videos that self-looping your setup should
be able to self-power your generator.
Any demonstration using LEDs and which does not at least show proper measurements is
pretty much pointless. Is that really so hard for people to understand? It should really be self-evident here.
Start point A                to                  Meta/Finishpoint B : 10 meters
10 Km/ h fast human velocity : from A to B 1/1000 hour ;
human KWh per hour : 80 Wh /1000 = 0,08 Wh energy for 10 meters
Stand point A : I or else with full gasoline 5 Liter can/ister and bringing the 5 Liter gasoline can/ister full to Meta/Finish point B
50000 Wh ~ 5 Liter gasoline
                50000 Wh : 0,08 Wh = work performance A-B
                                                   C.O.P. 625000
                                        using humans like simple machines
f.e.heat from start point A to Meta/Finish point B transporting  devices
                                              called heat pump or fridge
In energetischer Bilanzaufstellung : Idioten !
Raycathode
Hi you lot  :D lets stand back a moment and ask what are the risks ir Rick F comes out and declares full blown that he has free energy devices in kit form for sail hmm?
This site is open to any one to view on the plant, and only recently John Badini and his brother have left the planet under mysterious
circumstances and then you have Steven Greer talking about free energy devices being directly related to the existence of ET's and anti gravity and the 'Men in Black' appearing out of know where in open spaces and using so called death threats
and inventors disappearing or eradicated ect.
I mean would you behave much different to Rick Richard M Fried Hmm for F sake ? be realistic so if it works or not you ain't going
to get proof with the way things are! :-X
Void
Quote from: Raycathode on July 31, 2019, 10:06:43 AM
Hi you lot  :D ...
Hi Raycathode. Thanks, but you are just not helping with silliness like that.   :(
I could swear RF seems to be hypnotizing people... ;)
