Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
sm0ky2
Quote from: synchro1 on February 24, 2018, 10:44:54 AM
@smOky2,
The choke reads normal rated inductance immediately after the magnets are removed.
Wrong
It measures outside of its rated tolerance.
Did you never question "why"?
synchro1
Quote from: sm0ky2 on February 24, 2018, 10:52:58 AM
Wrong
@smOky2,
The issue here is whether the inductance meter measures an "Inverse Henry" or not.
sm0ky2
Quote from: synchro1 on February 24, 2018, 11:02:16 AM
@smOky2,
If the meter is giving you a false reading it would explain both the negative value
it is showing you on a normal copper wire inductor
As well as the false reading on the choke.
I'm not arguing against the magnetic field reducing the inductance
This is an obvious effect.
But for it to go negative, means you are inducing a reverse current.
and I don't believe this to be the case with what you have shown.
sm0ky2
I say that because the DMM you use is a voltage-biased device
and it shouldn't even be able to induce a reverse current to give that
measurement, in an unpowered circuit.
The circuit I posted will help you.
Swapping the clip leads with ones you know have not been magnetized
may also clear things up
synchro1
Quote from: sm0ky2 on February 24, 2018, 11:10:57 AM
@smOky2,
The meter is not measuring a reverse current it's measuring the presence of magnetic energy.
