Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Check this one out:
https://youtu.be/3ykm-blvC-U
I'm getting better (Attraction-Neutralization) off the kickback from my "500 Newton Electro-Magnet Coil" then with the series bifilar coil. This setup generates a huge amount of current in the "Electro Magnet Coil" from the attraction stroke as I've demonstrated in my videos. All it would take is one commutator Reed switch for output off the "Electro-Magnet Coil". I think I can place the output Reed switch on the other side of the Neo magnet spinner.I'll upload another video of this soon. I believe this combination will prove to be way Overunity.
synchro1
I'm shifting my emphasis away from the serial bifilar and back to the induction formula because I found my "Electro-Magnet Coil" outperforms the serial bifilar for the following reason:
Magnetic field strength is a function of inductance and input. Two coils, one with higher inductance and the same input will  generate a magnetic field whose strength is in direct proportion to it's weight in copper and core permeability.
The final design is a pulse motor with a tube spinner and magnetic axle bearings like Skycollection's. This spinner needs one adjustable output coil to regulate R.P.M. with Lenz drag. The spinner has two reciprocating "Reed switches" reverse biased on either side of the tube magnet. One's on for the pulse to the aircore power coil while the other at 180 degrees is off and viva versa. The output switch runs from the attraction neutralization electro-magnet to the destination; Load, capacitor or battery.
The electro-magnet coil is powered by "Inductive Kickback" from the aircore power coil. The output is channeled from the electro-magnet coil through the second Reed switch to the destination as pulsed D.C. during the attraction phase of the piston cycle.
The most important point here is that the output has an asymmetric relationship to the kickback input and is a function of electro-magnet coil and core inductance coupled with oscillating attraction piston magnet strength, not input power.
We're at the dawn of a new free energy era, and public announcement of this free power generator needs to be accompanied by a disclosure of a "Geo Resource" protection policy to avert market panic. Time to pop the corks folks! Every man a sultan and woman an equal.
synchro1
One additional detail; A timing wheel on the axle hub would permit us to extend the output discharge time with a latching Reed switch. We can increase power to the kickback oscillator and sustain the R.P.M. by repositioning the primary spinner output coil more closely to the magnet tube increasing Lenz drag. Naturally this would result in more output from both sources.
synchro1
Here's a video of the pulse coil back spike oscillating a ferrite magnet piston with an electro magnet:
https://youtu.be/Dvhixhl93Qs
The oscillation is greatest at low R.P.M. The piston begins to stand still as the Neo spinner speeds up. At:48 seconds into the video, the spinner R.P.M is gyrating the ferrite rod at maximum output frequency. I can't control the speed with this test setup, however it's very simple to regulate it with the addition of a potentiometer.
synchro1
These two Hob Nilre videos should both be watched; They are the essential key to understanding the Over-Unity principle behind the "Neutralization Attraction Oscillator":
https://www.youtube.com/watch?v=IIeRR6NjMPQ&t=30s
https://www.youtube.com/watch?v=zu_v7jMs-ms
"Double the copper - half the power. Or you could double the copper but same power - double the force, its just harder to measure".
Double the copper in the EM coil, we double the force for the same power; That would allow us to double the magnet strength in the oscillating piston and double the output through a Reed switch. The addition of a Reed switch timed to make contact as the piston is attracted toward the EM core, turns the EM into a hybrid output coil.
Art Porter had 500 pounds of circuitry under his test bench to generate the kind of pulse I'm generating with my Reed switch pulse coil.
