Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Here's a comparison of the outer and inner Uxcell SPDT switch. The outer switch has a cam lobe action that caused it to stick, so I removed the internal switch with it's linear press spring. This streamlined switch is the central component that replaces a cumbersome commutator and it's external power supply. I have this tiny internal switch sandwiched between two bamboo barbecue skewers and held in place with elastic bands. Works like a charm! Power in and power out being equal, that leaves the physical work of the magnet lever as a free energy source.
Here's a short video of the switch action:
https://www.youtube.com/watch?v=rnnW4a2WzgI
NerzhDishual
Hi experimenters,
I have not read this entire thread.  :P
Anyways, while we are at electro-magnets, just my 2 cents...
A French "patent" (in attached file) with some translations.
It is a not granted patent, you bet it is not as it claims OU.  :)
FR2363929 - BESSON- 6 septembre 1976
Générateur d'électricité mu par la force magnétique
Magnetically powered electricity generator - uses electric power output
to generate driving magnetic field providing free energy supply.
The generator derives its motive force from a magnetic field and is self-exciting
-- ie a part of the electric energy generated is used to create the magnetic field.
The magnetic field is produced by several electromagnets (1) fixed to a wheel (4)
driven by a motor (2). A mass (7) regulates the generator's ( 8) speed of rotation.
The wheel is linked via a chain (3) and pulley (6) to the generator.
The generator output is in turn used to power the motor, with the weight
(7) preventing excessive operating speeds.
Bien le bonsoir,
Jean
Nolite mittere margaritas ante porcos.
NerzhDishual
synchro1
This  Uxcell switch is actually a DPDT switch that I removed 1/2 the poles from. You can see four receptacle pin holes behind the pins below. This is a second switch. So we can use this switch to reverse the polarity. Turning two switches is too much work for the oscillator to shift.
