Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
The 12 volt timer relay requires  two power sources. The first one's connected when the press switch is closed in series through the oscillator switch. This starts the timer. there are three logic pins. K-1 sets the function then K-2 and K-3 set the timing first for the delay of the onset of power, then  the duration of the pulse.
It's possible to extend the power pulse along with the output duration, over the duration of the spring interval. This addition of this remaining componant will finish the build.
synchro1
Here's a video of the relay powering a tiny D.C. fan for exactly one second. This timer relay can trim the power pulse to a tenth of a second, inside the pulse width of the spring switch. Trimming the power pulse is an inverse approach to extending the output pulse ratio:
https://www.youtube.com/watch?v=PTZPugkKrp0
synchro1
Video of the oscillator pressure switch triggering the timer relay:
https://youtu.be/xqCJizD0xeE
