Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
32 3v LED's at full brightness should consume around 30 ma apiece. That's 960 milli amps all totaled. The D.C. wall transformer only generates 1000 ma (1 Amp), so the 32 LED's lit to full brightness would confirm that the output is equal to the input.
It would come as no surprise to anyone to find out that the oscillator speeds up when the load's connected instead of slowing down from Lenz propulsion..
The coil is outputting nearly six volts. A coil with twice the turns should generate close to twelve. That would allow for a closed loop.
This oscillator could pump water uphill all night for free while generating power. The accumulated head could deliver any amount of power for a period of time.
synchro1
I got it wired wrong. I made this mistake when I built the rocker version. The power positive needs to go to a switch electrode. I git it connected to the coil positive by mistake and I'm running power from the transformer through the output switch.
I corrected the mistake and installed a second SPDT switch in the PVC coupling. The voltage is set to go up ten times.
synchro1
Two DPDT current reversing switches, like the one pictured above, at opposite ends of a long solenoid coil would shuttle an axial polarized Neo magnet cylinder like a missile back and forth inside the air core, while opening the output pathway to storage or load.
synchro1
I got it rewired with the hot wire to the switch and it works about the same voltage sufficient to illuminate two 3v LED's in series. Here's a video:
https://youtu.be/5SOHIUFgfxg
