Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
                                                      <SPDT Micro Limit Switch "H" Bridge>
Ludic's video below shows how to wire an "H" bridge with two SPDT toggle switches. This allows for current reversing. A single coil can generate a power pulse in opposite directions with a monopole magnet piston. Two axial polarized magnet tubes with the same poles attached to a ferrite plug between them would act as a monopole piston.
Two SPDT limit switches wired as an "H" bridge on each end of the tube coil would reverse the direction of the coil polarity and supply power to the magnet piston from each end. One coil can drive a Scotch Yoke with a connecting rod extending from one side of the magnet piston, and two diodes, one from each end of the coil would connect to the positive of the capacitor and battery for the feedback loop. The output would be pulsed D.C.
Naturally linking two current reversing "H" bridge monopole magnet pistons to a scotch yoke would double the feedback power. One set of switches on each end would work for the two coils. Half the A.C. power is wasted by a half wave rectification of the changing current to the capacitor through the diode. The real advantage to the monopole "H" bridge is that the pulsed D.C. output would amount to twice the magnitude for storage in the capacitor.
We can completely eliminate any full wave "rectifier voltage drop", 81.2% maximum efficiency. This is important at 12 volts. With the pulsed "H" bridge D.C. output, all the feedback output would reach the storage capacitor with all the current traveling in one direction through diodes at each end of the coil to the shared battery capacitor positive in parallel.
https://www.youtube.com/watch?v=SpyGdoPPV7k
synchro1
This guy creates "Monopole Neo Magnets" by freezing them: Hw says they remain stable as monopoles at room temperature!
https://www.youtube.com/watch?v=fn4A6VJodow
synchro1
Connecting either two outside pins acts as an SPDT common. This micro limit switch was pirated from a push button lamp switch. It's a bit smaller then the other switch and fits more easily into the tube. Perfect for the current reversing "H" bridge.
kampen
Ref.: YouTube videoclip >How to make a MONOPOLE MAGNET<
Sorry to tell You but THIS is FAKE!
synchro1
Quote from: kampen on April 08, 2019, 01:52:43 PM
Yup! I just tried it and it failed to work. Got me again. Damn it!
