Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Here's a video of the oscillator lighting a small bank of reverse biased LEDs: Next I plan to add additional LEDS to the rail to see how many it can illuminate.
https://www.youtube.com/watch?v=JiCXHFwpIUs
synchro1
Here's a schematic of an LED identifying the long electrode as the anode or positive;
synchro1
Here's a video of the oscillator lighting 12 LEDs on flyback. The 3 volts D.C. will only light 1. Frequency increases LED light intensity: The anode or positive electrode of the LED, (The longer prong) must connect to the negative contact and the negative or shorter prong to the positive end of the coil to light up from the oscillating flyback. The 3 volts of D.C. current will only light one LED connected the other way around, the way they're designed to work, with the anode to the positive and the cathode to the negative pole of the two AA batteries in series.
https://www.youtube.com/watch?v=6BDAX8Lm1kY
The power that illuminates the 12 LEDS in this video is strictly a function of the copper mass in the spring coil and core permeability, not the input from the AA batteries. This is a clear example of an Overunity generator in action!
synchro1
I measured the oscillator coil inductance at .010 mH (milli henrys) with the AA batteries acting as a coil core and .004 mH alone as an air core coil. This test demonstrates that the AA batteries act as a very powerful core material, more then doubling inductance over the air core. This factor alone more than doubles the magnetic field in the spring coil and more than doubles the flyback power from the field collapse.
sm0ky2
The difference between an a/c signal (reactive power)
and a pulsed d.c. signal (negative inductance)
is the off-cycle.
No current is drawn from the source during field collapse.
if the load is powered only during this time
The power through the source is only a factor of the induction.
The Lenz/Lorentz force is only fighting the free-space induction
not the current from the source.
There are no changes from source to load.
The source basically does not see the load.
