Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Adding magnet strength to the MMM (Mostly Magnet Motor) increases inductive kickback along with coil torque. Luc adds a latching relay to his SPDT switches. Inductive kickback increases with frequency of power interruption. The "Echo Canyon" of Adams resonance, not the mechanical throw, is where the COP advantage is greatest with this kind of super build.
Oscillating in Adam's resonance, the "Inductive Kickback" delivers half of the motor power! Vibration transducers provide a superior output in the millimeter throw range.
__________________
synchro1
What would this current reversing monopole oscillator be called? Too bad he can't get the magnet rod to work his switch.
https://www.youtube.com/watch?v=ys2-wTU5w4E
synchro1
Quote from Gotoluc:
"So to please everyone I did tests to see if the super build could have OU potential even though I knew it would not since the design also suffers of the generator effect as the coil moves in the permanent magnet field. Since it can only move at a certain speed because the coil generates power as it moves, it fights the input power which is coming in the same direction, so we cannot beat the laws of physics here".
Everyone can see from Luc's final conclusions that his (MMM) failed to benefit from any propulsive "Delayed Lenz effect". Removing the latching relay in his motor circuit would allow it to Oscillate in Adam's resonance; Doubling it's power by dovetailing the inductive back kick instead of fighting out of phase like Luc describes it doing.
__________________
synchro1
Overunity achieved by the magnet assisted flyback from the EM coil oscillator and Neo tubes magnet: Battery voltage rises from .82 to .92 during the 2 minute run!
https://www.youtube.com/watch?v=NzQtyFp_Ghk
synchro1
The metallic electromagnet caseing is attracting the overhead ferrite rod with the Neo magnet attached to the end on an elastic band.
One end of the battery is attached to an electrode positioned on the surface of the electro magnet connected through the electrodes of the electromagnet. The other end is runs down the ferrite rod to an exposed end. The polarities repel the rod or neutralize the attraction. When the current is interrupted, the flyback returns to the battery from the reversed polarity of the backspike and charges the power source. A clear demonstration of magnet assisted flyback over unity.
Why is it that this proof of Overunity is completely ignored?
