Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
The attraction force from the polarity reversal has to do more work because the return force has to fight the back tension of the elastic band. The attraction to the Electro-Magnet's metal casing is equal on both strokes from the magnetized ferrite piston, so that leaves the power pulse and the "Adams Attraction Flyback" reversal force to compare: Basicly, it simply costs less to release then it does to catch and return it!
The power pulse merely needs to equal the attraction and neutralize it. The "Adams Attraction" flyback power has to compensate for the upward acceleration of the piston as well, so therefore; Has to be greater!  The amplification effect of the backing magnets increases the powers of the backspike's both reverse magnetic force and electrical recovery, and causes the over unity.
I demonstrate this oscillator charging a 12 volt battery at the rate of a wall charger!
synchro1
6 backing Neo discs under the 12 volt electro magnet, 1 on the ferrite toroid in attraction and a razor blade with a magnet wire for mosfet gate source voltage in between. A second magnet wire travels up from the Torus with the elastic band as a sensor.
The proximity field effect triggers the current interruption. This oscillator's COP is OU from the combination of Neo magnet amplification of reverse flyback current and Adam's attraction.
This generator should be sufficient to sustain the flight of an "Ion Lifter". This concept may ultimately prove to be more efficient then any other form of Energy!
synchro1
This 12 volt 1000 Newton Electromagnet is 20 times as powerful! Imagine the output it could generate with large Neo discs amplifying the interupted power pulse:
synchro1
"To turn the MOSFET on, we need to raise the voltage on the gate. To turn it off we need to connect the gate to ground. P-Channel – The source is connected to the power rail (Vcc). In order to allow current to flow the Gate needs to be pulled to ground".
The Razor blade is connected to the ground, and the exposed magnet wire under the toroid to the MOSFET gate.
This results in a silent, vibrationless "Spring Balanced Transistorized" mechanism that is entirely frictionless. Self timed in Adam's resonance and perpetual.
Naturally, a recovery diode would be essential to send the output back to source, to a storage capacitor or direct it to a load.
synchro1
A second electro magnet attached to the other side of the magnet stack in series with the pulse magnet would double the output just by connecting it!
this twin would allow us to enclose the magnet stacks in output coils. piezo transducers would serve too. elastic bands or a center spring needed.
this could power a pancake compressor from the interior center.
