Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
 :P
  MAGNETIC FLYBACK AMPLIFIER
Two Microwave "E" core transformer stators with 16 1" Neo magnet cubes attached "Cris-Crossed" and in opposition will attract each other and lock when placed in Chiral adjacency. The size of the air gap and the spring tension would determine the frequency and voltage output of this attraction neutralization flyback recovery "Resonator".
The primary coils work backwards from the way they would as electro magnets.
A recovery diode Mosfet and Capacitor should self loop and trickle charge a wall battery non-stop free of charge! The mass of copper, Weber's of flux and precision tolerances combine to raise the power potential of this generator to the Maximum!
synchro1
twin primary microwave transformers in opposition;
synchro1
The "E" core magnet positioning has some field characteristics allowing for this innovation:
Current reversing "H" bridge rocker; 2 pins are fused at the end of each 4 pin switch and are connected to the ground. This setup needs two diodes and outputs an AC backspike.
https://www.youtube.com/watch?v=TsjuGSqQmX8
synchro1
This is generating 10 solid volts of A.C. flyback output as an "Inverter Amplifier"!
  https://www.youtube.com/watch?v=Teg-qFcPrYs
