Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Imagine how a GAP toroid magnet coil and BEMF recovery circuit might power this circular "V" gate over unity:
                                       Start this video at 2:30!
https://www.youtube.com/watch?v=B9sT25v372I
The difference between this circular "V" gate and "Quanta's Magnetic Wankel" is the stator magnets are internally wound with output coil's and are generating power without a second set of magnets for output. The magnet missile is levitating through the gates. Below's a still shot of it shooting out forcefully, but with insufficient power to push through the cog spot. All the magnets face in the same direction, are 18 slanted magnet blocks; Hexagonal 3d gate sections with 6 sides of 3 small rectangular block Neo's at 45 degrees. The missile is axial polarized.
synchro1
Like this: The magnet missile would act as the magnet core for the amplified backspike recovery; Proper tuning would deliver "Lenz Propulsion" in Adam's resonance. Reed switch to ground and MOSFET GATE. Recovery diode.
synchro1
Holding the magnet projectile in place in the pulse coil cores, then charging and interrupting the current to the coils and sending the backspike alone through the output coils connected in series should return more power to the capacitor then supplied to the power pulse! A solid state Hans Kohler type generator.
synchro1
A race of ceramic bearings on the shuttle magnet would help. The Cannon Coils are bucking and wound on the same former as the originals. This should really fly with the core evacuated. Good "Hyperloop" concept.
The shuttle magnet can be enlarged into a solid ring simply by attaching them end to end. This would turn it into a powerful generator. 200% OU with the recovery circuit.
The solid ring rotor would levitate and no longer require bearings. There nested tubes. The rotor tube may go Mach velocity.
A "Flywheel Battery"! A solid round magnet ring with multi impregnated Poles.
