Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 176 Guests are viewing this topic.
synchro1
LEDS oscillate and generate power identically to the way the "Battery Magnet Oscillator" does; Adding LEDS in a string may appear to dim the individual bulb, but the overall light output increases with the addition of more bulbs.
A photonic reactor with photo generating panels attached to the inside of a ball with a sphere of LEDS in the center would let us plug into it and run our campsites.
synchro1
A "REED SWITCH" would run this oscillator best! The contact can't be beat confined by a vacuum tube.
"Skycollection" could run his "Hexafilar coil" and bank of LEDS with two C cell batteries in series as a coil core and a magnet at the base in series with the Reed switch.
synchro1
Mag amp effect.
Another advantage of this magnet battery oscillator is that the permanent magnet field that penetrates the copper coil acts as an electrical resistor, (Mag amp effect) increasing circuit efficiency.
synchro1
Bosch patented the "Magneto" and out of it evolved the ignition coil that involved a set of breaker points to jump a spark. Viewing the Reed switch as ignition points one can see how this magnet battery oscillator is really a "Bosch Ignition lighting system".
synchro1
Constructing a receiver of the same dimensions as the transmitter magnet battery oscillator, could broadcast and receive morse code with an interrupter button!
