Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Ludic science has a magnet oscillator coil of 4 turns around a tiny Neo disk, that makes contact with the negative pole through the inductor. The split positive version would use this "Ludic Contact" to run from the positive pole of the 9 volt battery to the bottom end of the AA battery coil that attaches to the positive electrode of the AA's overhead. The negative poles would be attached to each other. The thin gauge flyback output leads would attach to both ends of the AA coil. This is a cheap Over Unity design that anyone can build at home for peanuts.
synchro1
I succeeded with the "Ludic Science" magnet coil trigger:
https://www.youtube.com/watch?v=COLDfC6aPFM
This was just a first attempt to act as proof of concept. This attempt leaves enough room for improvement.
synchro1
In the video above, a red clip wire can be seen running from the positive pole of the primary Duracell AA on the left, to the start of the jumper coil. This wire would be replaced by a copper wire inductor wrapped around the Duracell. One end of the coil would attach to the positive electrode of the AA and the other end to the start of the "Jumper Coil".
The main LED load would be powered by flyback output from the AA coil through thin wire leads attached to the ends of the coil like my original magnet battery oscillator.
This "Mechanical Joule Thief" setup uses two semi novel approaches from (LOstFox and Slayer): One, the split positive to conserve the pulse and extend run time, and the other; The high perm AA battery coil core that increases inductance and magnifies the flyback output to the reverse biased multiple LED bank.
synchro1
The 12 volt battery in the video measured 5 1/2 volts at the time of testing. The primary AA 1 1/2 volts. The voltage measured from the top of the primary AA was additive at 7 volts. The voltage on the second AA 1 1/2 volts again; That yields a 5 1/2 volt differential.
Adding a second AA in series with the primary AA would increase the differential to 7 volts. The greater the differential the more powerful the oscillation.
Doubling the length of the flyback inductor around two AA battery cores would double the output to the LED's for the same input, along with increasing the differential.
Inductors in series act as resistors in series and are simply additive.
Adding primary AA batteries in series along with the inductors does not have to result in too long and ungainly a core coil. The AA's can be positioned side by side; Both the battery electrodes and copper coils need to be connected to each other end to end. Imagine a cube of 9 AA's in series for the primary!
9 AA's would deliver 13 1/2 volts; This would create a 12 volt differential between them and the positive electrode of a 10th AA; Nearly twice the strength of the video setup differential.
The additional feature involves the advantage the 9 high perm AA coil cores, and the increased inductance of the nine flyback output coils in series!
What's happening to the COP of this oscillating boost converter? It's doubling and quadrupling along with the rising differential!
synchro1
I measured the AA "Energizer Rechargeable", and it has the same 3.5 to 1 advantage in inductance increase over the air core as the Duracell Quantum.
I calculate the permeability of these two AA's at 350.
Inductance of a copper coil is a coefficient of Ohms over Henries. Increasing inductance by adding copper windings increases Ohmic resistance and increases the impedance. Increasing inductance through core perm avoids this drawback.
Lasersaber abandoned his "Super Joule Ringer" because our ferrite core manufacturer raised the price on the product after he invented it. His ferrite core had a permeability of 1000. The high cost of the product grew prohibitive.
Akula's self runner has a 4" diameter pot core with a light internal winding. That's the ticket! Inductance through core perm rather then increased copper coil windings.
The "Energizer Rechargeable" is the best AA battery of choice for the "Mega Super Joule Ringer" with a AA core perm of 350. One layer of copper windings would reduce Ohms and keep impedance down to a minimum.
Naturally, the rechargeable AA will allow us to rotate the charged battery by Tesla switch indefinitely.
