Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
My attraction neutralization oscillator caloric measurements have opened a new amplification approach that multiplies the oscillator COP by thousands of times:
MCE, or "Mageto-Caloric effect": The presence of the external permanent magnet field raises the temperature of  the cobalt alloy  electromagnet core, and the neutralization pulse cools it.
The currie point of Gadolinium is 20 degrees centigrade. This is close to room temperature.
An Attraction Neutralization oscillator with a Gadolinium core would increase the field differential thousands of times. The EM power pulse would neutralize the powerful external field, cool the gadolinum core and cause it to grow magnetic. When the external field reappeared, the core would reheat, loose it's attraction strength and release the magnetic piston.
The output would be equal to the electrical power it would take to generate the field strength to match the magnetic attraction of the gadolinium core. This would all be "Free Power".
synchro1
Here's a very simple design for an over unity MCE solid state generator:
An axial polarized neodymium cylinder wrapped with a copper coil and connected to a power source so the two fields reinforce each other; Placed in adjacency to a "Gadolinium Cylinder" would generate power when pulsed under the following conditions:
The ambient temperature is close to the Currie point of 20 degrees centigrade. The combined field strength of the Neo magnet and coil is sufficient to raise the temperature of the "Gadolinium Cylinder" above the Currie point so it relinquishes it's magnetic attraction. Upon de-energizing the magnet coil, the temperature of the "Gadolinium" would drop, the attraction strength would return and the permanent magnet field would be drawn toward it through the coil wraps generating a current therein.
synchro1
Here's a terrarium temperature control setup for $30 dollars off Amazon that uses an electric fan and electric heater to control temperature down to 1/10 of a degree centigrade. Plenty of tolerance to house a very powerful solid state currie point MCE generator:
synchro1
A neo horseshoe magnet with complimentary coil and a gadolinium stator linking the poles would open and close the magnetic flux gate inside the climate control zone.
We need an SPDT switch to run it. Energizing the coil would raise the temperature of the stator above the Currie point and close the flux path. De-energizing the horseshoe magnet coil would lower the temperature of the gadolinium stator, and open the flux path between the horseshoe poles, generating output from within it's own magnet coil, directing the output to the destination through the SPDT switch. No moving parts.
The climate control unit would be portable and fit in a car trunk or VTOL cargo hatch.
synchro1
Here's a 3/4" diameter gadolinium coin and a schematic of the Flynn multiplication of force concept:
Two Horseshoe magnets connected through two gadolinium coins would produce the phantom force of a third magnet when the flux gates are open.
