Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 140 Guests are viewing this topic.
synchro1
The contacts in the limit switch act as the contacts in the reed switch. The schematic is nearly identical to the oscillator wiring. Igor's BEMF is A.C. and his reversed biased LED acts as a half wave rectifier. He's nearly over unity with under 1/2 the BEMF sent back to the battery as the "H" bridge monopole can deliver.
https://www.youtube.com/watch?v=vWvI7T7h3tk
synchro1
This monopole spinner would deliver the same D.C. flyback as the "H" bridge wired like Igor's Reed switch Spinner 2. Connecting the cathode of a silicon diode to the top of the coil and the anode to the positive pole of the battery would return twice the BEMF to the battery as Igor's bipolar Neo sphere spinner does. This one's a flyback goldmine and the basis for many of John Bedini's designs and patents.
The difference is we're pulsing the magnets inside the core of the output coil. This collects additional power through "Quantum Induction" from the magnets.
https://dl-mail.ymail.com/ws/download/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==APnzqMtxM8McXLm4ag2UkD3lGE0/content/parts/@.id==2.2/raw?appid=YMailNorrinLaunch&ymreqid=3365852a-c14e-b304-1c9e-2f0000012400&token=zitEzqOML3j84e6ealFTT5U7-km5qEQF52lp7AcCuBYuSfoFz8vQYu01Ebe_f8pg2ITMlv4-3AvnkLQDemZLxHwtsH6_HC8hR_TqMSR7KK7Kq2x236OSj64rSSjwoc6v
synchro1
The Bedini Monopole Oscillator employs a wheel with magnets attached with the same pole out. That leaves dead space between the magnets the "H" bridge cuts out. The "H" bridge magnets are alway positioned inside the coil core, not separated from the coil by a distance on the rotor circumference. The rotor with interspersed magnets only delivers a fraction of the Webers to the output coil the "H" bridge oscillator oscillator does in a specific time frame.
synchro1
                                                The double reverse synchronization.
The oscillator can catch an extra kick from the power stroke when the pole reversal of the Inductive kickback couples with the "H" bridge reversal. The Adam's motor can be tuned to work this way and when the piston magnets are positioned correctly the forces couple to deliver more power.
That makes a second major efficiency dividend for the Oscillator. Combined D.C. diode transferred BEMF output, and twin Adams kick, not opposed serially like the Adams motor but coupled in parallel.
synchro1
The threaded base of this fixture has an ID that allows the SPDT limit switch to fit tightly inside; Also it has the threaded bushings for the screw threaded tube for fine tuning. It takes two of these:
https://www.ronnieshardware.com/products/plumbing-028905703017
