Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
@lancIV,
Thanks for the extremely helpful links!
Nothing could be simpler! The two coils are wired to the two switches so that they neutralize the permanent field in opposition.
So, the energized coil in opposition to the polarity of the magnets, draws the flux away from the other leg, and when the opposition coil is fired, it heads in the other direction!
The two teetering SPDT rocker switches accomplishes this task!
This generator needs two recovery diodes. The back spike is assisted by the evacuation of stator field caused by the neutralization pulse of the partner coil.
https://www.youtube.com/watch?v=VfptuTeRdb0
pure DC- or pulsed DC or AC calculation formula and measurements ?
above video : Comment
stephen wallinvor 4 Jahren
Since from this video I do not know were this is leading, but adding the magnets to an AC coil core only affects each alternate AC cycle, alternating as a shunt and then increasing the flux on the next cycle.
The shunt is reducing the efficiency for a half cycle , then increasing it for the next, but with a hysteresis effect that reduces the increase to give an overall decrease combined with the more efficient shunt effect.
The power in will go down, but speed will not drop much, as speed depends on frequency as well as voltage. And frequency causes a major issue,
Watts =VxI and all equivalent formula work only with pure DC, not AC waves forms of any type.
An amp meter will not show the true amps, not even an RMS value, as the wave form may not be a pure sine wave. the only way is to work out the area of the wave, difficult with most equipment even a scope.
Also volt meters on AC settings are designed to handle AC in the range of 50/60 cycles per second, pure sine wave, and cannot be trusted on higher or lower frequencies.
I should add I designed motors and transformers in industry, now retired.
MEG : http://alt-sci.ru/en/wiki/Vortical_transformers
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990720&CC=US&NR=5926083A&KC=A
or
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=JP&NR=2003009558A&KC=A&FT=D&ND=3&date=20030110&DB=EPODOC&locale=en_EP
translated description :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=2003009558&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
[0017]
According to the present invention, as described above, a permanent magnet magnetized to a required magnetic flux density is sandwiched by a yoke made of a soft magnetic material having a high magnetic permeability, and the magnetic flux direction of the permanent magnet is changed in one direction. A magnetizing coil is provided on one side of the yoke for generating a magnetic flux substantially equal to the magnetic flux of the permanent magnet running in the yoke and generating a reverse and forward magnetic flux in the direction of the magnetic flux. A magnetizing unit, an induction yoke made of a soft magnetic material having a high magnetic permeability and connected to the magnetization unit, and an induction coil for extracting an induced power accompanying electromagnetic induction is provided on one side of the induction yoke. And the output units are connected alternately and appropriately in number and their edges are closed, so that only a small amount of AC power is input to the magnetizing coil of the magnetizing unit to magnetize the inside of the yoke. Strong magnet of permanent magnet An alternating magnetic flux is generated in the reverse and forward directions, and the running magnetic path of the magnetizing unit is opened and closed, and the magnetic flux generated by the magnetizing coil is added to the open magnetic path in addition to the magnetic flux of the permanent magnet. Is also demagnetized and magnetized by the connected output unit, and when a closed magnetic circuit is formed, the magnetomotive flux in the magnetized unit is significantly increased. Since the output unit is alternated in accordance with the frequency, a high electromagnetic induction effect occurs in the output unit. Due to the magnetization of the output unit due to the open magnetic path of the magnetic field, a magnetic path is formed around the entire configuration, and the interaction caused by the formation of the circular magnetic path causes the magnetization from the magnetized unit to the output unit to be one step higher. Strong it is promoted electromagnetic induction to work. Therefore, by designing a specific magnetic circuit based on the AC power source to be used, its frequency, and the desired output power, it is possible to obtain output power several to several tens times as large as the input power. The equipment is small and easy to produce, so it can be realized at extremely low cost. It is a power generation method and a power generation device that greatly contribute to the realization.
synchro1
Just needs a rocker switch and we should be in business!: Two synchronous Washtub pump motor stators and two one inch cube magnets:
synchro1
This hopper can trigger a MOSFET: The rocker is a ceramic block magnet in spring opposition. It can serve as a "Rocker".
https://www.youtube.com/watch?v=6r3tXEKzBu0
