Graphene provides limitless free energy
Started by Belfior, December 04, 2017, 03:06:43 AM
isawit
lots of theoretical nonsense being portrayed as science. em theory, qm, relativity, tbb, black hole, photon, time travel, dark matter, simulation.
computer simulation can only produce digital signals, real world is based on matter and energy.
time is not a place, time has no location, where to travel? how to travel to no where?
simple facts, can you see it?
i doubt, you never questioned science theories, am i correct?
isawit
voyager is fake, gravity is decelerating it at all the times, how can it escape from solar system?
iss is fake, ac systems cannot work in vacuum space, heat cannot radiate into space but matter.
einstein is wrong about time dilation.
put same atomic clocks in the sun, earth, mars, flying air plan, for 1 day.
each clock will have different reading.
which time is dilated? which clock has correct time?
time dilation is misinterpretation of timer's moving rate/reading affected by gravity/acceleration/force upon it.
time is not a thing, time has no location, cannot be touched, what is dilating what? how?
the most famous equation e=mcc is BS
mass is condensed charged particles. energy is emf matter carried. totally different, cannot equivalent.
a 1 kg gold bar at rest has no energy but thermal energy, for it to carry 1kgcc energy, it must move at 1.414 c speed. how fast can we move a bullet?
nuclear energy? 1 kg best fuel, how many % of it can produce heat?
the most famous experiment double slit is BS
light is not wave nor particle, but electron's vibration force. put double slit experiment in a vacuum chamber, wave property will disappear.
have you doubt any scientific theories? debunked any? disproved any?
i showed you how to win a nobel doing double slit experiment in vacuum, did you even care? i saw no comment from you in that thread.
isawit
if heat can radiate into space, earth will be as hot as the sun, the whole universe will be at same temperature, thermal equilibrium.
is that a fact?
isawit
think deeper, you may ask, if of heat cannot radiate into space, why all the energy we produced/used from the past didn't make earth warmer?
very good question. some of you might know the answer already.
if you cut a channel between a pond and ocean, the water level will be the same.
if rained 10 foot in the pond slowly, the water level will not raise at all. both in the pond and ocean.
the repulsion force between lines of sight electrons on surface atoms of masses/matters f=Ke x ee/rr is the water channel, thermal energy is water, mass is water container.
thank this thread and everyone, sweet day!
isawit
Quote from: isawit on December 09, 2017, 08:33:54 PM
all energy is emf, must carried by matter. all things happening is caused by emf.
all things happening is at now, all existence is at now, emf moves around, changes container, but it can never stop moving. time is forever ongoing now, all past became now, all future will become now.
now is all the time we can act.
if you love someone, act now. see right thing to do, do it now.
then you shall be free from regret.
